LF pics of your aftermarket tach install on stock dash setup?
Wondering if anyone has any pics of a tach mounted on the stock dash, maybe towards the left on the top? Probably to bulky, just wondering.....
Re: LF pics of your aftermarket tach install on stock dash setup?
Would like more functionality than that though, large tach=easier to read in a pinch, and also a shift light, but I guess I could rig up a shift light set up with the stock tach, right?
thats what i have- bought a harlan shiftlight- its mounted in my AC vent pointed towards me. Wired to the PCM tach wire. works perfect for me, never really saw a need to have a big tach. I just set the shift light for couple hundred RPM's under where i want to shift to make up for reaction time
I managed to use a big hose clamp (covered in heat shrink), and put mine on the column.With the mini-shift lite, It just barely fit. It also covered the stock oil PSI Gage, but I have my Autometer in the pillar anyway.
http://www.installuniversity.com/ins...sity/index.htm
instructions for installing harlen or similar light into vents- to give u an idea
I didn't like the visibilty issue with it on the LF, so I mounted mine on the RH side. I like it much better there.
10-31-2016 11:09 AM
