Installed Recaro seats, I have a seat belt issue.
I drive a 2002 Z28, black leather.
I removed the OEM seats and installed a set of Recaro Style seats.
The OEM seats had a seat belt loop screwed to them which routed the belt over your shoulder.
The new seats have no provision for this and no place to mount the OEM plastic loop. Because of this the belt rides on my neck and besides being uncomfortable it could cause severe neck trauma in an accident. There is no way to move the plastic loop over, which is held in place by two screws, because the new seats are nothing but foam. nothing hard to mount to.
Surely I'm not the first person with this problem. Is there a solution for me? Thank you.
This seat doesn't even have holes for that. I also don't have a roll bar. These are more touring seats than racing seats.
http://home.attbi.com/~bartlane/seat.jpg
i had the same problem........then i came up with the master plan i mean it took a while to do it
its custom
DONT PUT YOUR SEAT BELT ON!!!!!!!!!!!
thats what i do.....or dont do
ON A MORE SERIOUS NOTE.......
but i think wearing race harnesses is illegal
u can probably make something that u can mount to the car that makes the seat belt come out more
its custom
You didn't drill into those did you? It is a pain to get the seatbelts not to decapitate you, especially without the harness slots. I believe Steve2000SS has them on his, you could ask him how he did them. I finally bought my 5pt harness today to run through my Sparcos. But I have a cage.
Hey 1coolpc,
Can you post pic on exactly how you're mounting the loop? I'm guessing you fabricate something that goes arount the headrest or something? I anticitpate the same problem when I get my new seats.
Thanks!
Aria
Thanks!
Aria
Here are a couple shots of the bracket I made. It was 1" wide steel and I had to bend it in a vice. Very sturdy. I covered them in black cloth tape but you can't see them regardless. They stay fast in place because my measurements were tight. Even if you pull up the head rest (For taller people.) the belt bracket will rise up with it, staying fast directly under the rest. This will raise the shoulder point for taller drivers as it should be. If you notice I cut a notch on each side of the bracket instead of two on one side. This makes a sturdy locking mechanism should the belt be pulled forward as in an accident. Any other way could turn that flat piece of steel into a knife being pulled forward. Make sure you make your notches like mine. When you tug forward on the belt the bar can not move no matter what.
http://home.earthlink.net/~bartlane66/bracket1.jpg
http://home.earthlink.net/~bartlane66/bracket2.jpg
Many thanks! That helps a lot.
I wonder if the Mitsubishi Evo 8 has a belt guide. I was looking at pictures of sports cars, and I could've sworn a couple don't have the guides...
Thanks again for the pix!
Aria
Aria
