identifying different SS hood types
Old 03-07-2005, 03:48 PM
marshall93z's Avatar
how can you tell which is which? here is a pic of mine...just need to get it painted.
http://img29.exs.cx/img29/209/hood9kd.jpg
and is it fiberglass or composite? looks like fiberglass underneath a layer of white stuff.
http://img29.exs.cx/img29/394/cracked1dl.jpg
marshall93z is offline
Old 03-07-2005, 03:49 PM
Re: identifying different SS hood types
and what would i use to repair it?
Old 03-08-2005, 05:06 PM
come on guys...someone has to know what brand this hood is!
Old 03-09-2005, 06:22 PM
DrewHMS97SS's Avatar
with the cracking that is going to pita to fix. you are going to have to cut that corner off the hood and make it. If you dont the cracks will come back the first time you close the hood. I would take it to a shop that knows whats going on.
DrewHMS97SS is offline
Old 03-10-2005, 11:35 AM
Z28SORR's Avatar
This appears to be a "Standard" aftermarket fiberglass hood and should be fairly easy to repair. You should not need to cut anything off. Get a book on fiberglass repair and go do it. The white stuff is either Gelcoat or, more likely, body filler used to improve the look of the under side. Most auto parts stores will have both the book and the fiberglass repair kit.
Z28SORR is offline
Old 03-10-2005, 09:28 PM
cool...
Formula Steve
09-19-2023 08:31 AM
WobblySausage
10-07-2015 02:44 PM
alliance12364
09-17-2015 08:43 AM
gearhead3
Parts Wanted
09-16-2015 08:18 AM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: identifying different SS hood types
