I want some foglight assemblies to fill the holes
Old 03-08-2005, 10:44 PM
lt4 fd's Avatar
What is all involved or needed to get the foglights in the bumper of my car? LIke what wiring and stuff will I need is there any aftermarket companies that make one or is it a ... dealer only . If its dealer only I might want some blackouts... if anyone knows where to get those that would help too.
lt4 fd is offline
Old 03-08-2005, 11:18 PM
psykoTA's Avatar
Re: I want some foglight assemblies to fill the holes
Most foglight kits come with all the wiring needed. I would measure the holes and find a light with those dimensions--make some brackets--the bolt em in.
psykoTA is offline
Old 03-09-2005, 10:04 PM
Z28Nut's Avatar
Hella FF75 or FF50s fit in the openings very well and are much better than the factory fog housings. Much less expensive, too. The FF75 fog light kit can be found for around 40$ but the factory housings are 100$+ each and I don't know what they want for the factory brackets. A 3"x6" piece of flat steel (1/8" or 3/16" thick) needs to be drilled to fit the factory mounting holes on the bottom of the lower rad support and drilled for the fog light bracket. Try a search on fog lights or FF75, we had a thread on how to do this but I don't have a link handy.
Z28Nut is offline
Old 03-09-2005, 10:31 PM
lt4 fd's Avatar
Thanks man!.... er wait I am talking about a trans am's circular holes in the front bumper cover type fog lights...
lt4 fd is offline
Old 03-09-2005, 11:07 PM
AW/whiteZ-28's Avatar
Lt1 formulas don't have circle fogs?
But here are some links to some T/A fog installs
http://www.ls1.com/forums/showthread...rans+foglights
http://web.camaross.com/forums/showt...rans+foglights
AW/whiteZ-28 is offline
Old 03-10-2005, 12:46 AM
psykoTA's Avatar
What car are the lights going into? I just fiinished mounting a set of Blazertech 3200 foglights in my 00 TA. 4" diameter as compared to the 4.5" stock lights.
psykoTA is offline
Old 03-10-2005, 10:03 AM
lt4 fd's Avatar
A formula with a trans am front bumper. Thanks guys I think those last few links are what I need.
lt4 fd is offline
94Z28LS1toLT1
10-04-2015 11:28 PM
Noct
07-14-2015 01:18 AM
Boss002
07-09-2015 03:33 PM
SergheiS
07-05-2015 03:27 AM
Quick Reply: I want some foglight assemblies to fill the holes
