I have an idea, tell me what you think
There should be something available to purchase that can cover your T-tops when they are off. I dont know about you guys but when the t-tops are off, I hate the look of the dull paint, nuts bolts and seals showing. They should make a black plastic or fiberglass piece that snaps or slides into place to finish it off. There has to be some way to make it look more presentable.
Yeah i could see this working. How about instead of make a "cover" you make it permanent. Im thinking basically cover it with fiberglass so that you get that clean look. And then just paint it. I painted mine, but it still looks a little dull.
this seems like a job for vinyl molding. make it soo it snaps in place somehow and its flexible, might be able to do it as one hole piece.
IF you wanted it pieced, then i'd do fiberglass in 3 pieces with a similar latching method that the convertible covers use.
That is an excellent idea, i used to think about that when i had my ttops.
My only issue with this is that its one more thing to have to worry about when taking the tops off and on. I never use my covers for my vert
Originally posted by KnightRider2000
TTIWWP
I have a hard time grasping the imagery here
TTIWWP
and I definately see what you are getting at stang killa
My crafting skills have been untapped (so there might not be anything there ) but I wouldnt even know how to go about starting this type of project
i'm having trouble grasping this too.. why would you want to cover the area when the ttops are off?? the whole point of taking them off is to to get air into the car and whatnot.. putting plastic over that is almost the same as just leaving the tops on
maybe i'm confused
maybe i'm confused
I say two pieces. Imagine the t-tops being on the car but with the openings cut out. the only thing it covers is the exposed weatherstriping. imagine the shape as a "U"
My idea is to somehow use the same holes that the ttops latch into. maybe some kind of bolt that you push in with your thumb... but also pops out wtih the push of the thumb... like a PEN... got me?
i think that should all come painted black too... unless otherwise requested.
I wish I could SHOW you guys... because i really think it would work and look VERY good... maybe i'll try to draw a picture if i get some time.
wow props for whoever had the initial idea... i can visualize it.
You guys are talking about something like this?
http://blackbowtie.web1000.com/image...ttopcovers.jpg
I think it would be a great idea. And I don't even have T-Tops.
