How tight should these front latches be on my vert?
I recently tighten the two front latches on my vert. I turned them one full turn and they are tighter and the vert does seal better. They do not seem to tight but I want to make them tight as possible and I was wodnering how tight are you suppose to tighten these latches?
Thanks,
Chris
Thanks,
Chris
Should be easily closed using just your thumb. The front seal should not leak, as this is a very good design. It's recommended that you clean then coat all the top seals with silicone based or dialectic grease.
96SilverRam
11-20-2016 11:19 AM
REDNECKISBOSS
05-20-2015 10:03 PM
guionM
18
07-11-2002 01:45 AM
