How to properly clean a windshield?
Re: How to properly clean a windshield?
I normally use Invisible Glass. That said, newsprint works wonderfully when you are simply drying a wet car after washing. All water spots are removed with a vigorous rubbing. I grab a section of the paper and use 1 sheet at a time (crushing it into a sort of ball). Change sheets as you move around the car.
I've had good luck with Invisble Glass. Although lately I had to break in a NanaSkin Mitt and it suggests breaking in on Window Glass - A big Difference - Clay Bar on Glass....
They offer a Speed Prep Sponge for quite a bit cheaper that would probably work out well for glass!
Oh and I use Optimum No Rinse (Clay Lubricant Mixture) as the lube/cleanser
klaymon
10-09-2001 03:54 PM
SSRox
08-05-2001 02:33 PM
