Hood Vents?
Hood Vents?
Has anyone ever taken out the inner part of the hood vents? I was just wondering how different it would look (if at all).
Could it possibly help in any way?
Could it hurt?
I've seen the grills that MBA makes for the vents, but I was thinking of just taking
them out and leaving them open.
Let me know what your thoughts on this are!
Thanks, in advance!
E
Ernie's 1994 Camaro Z28
Check my site for info about my car!
Could it hurt?
Thanks, in advance!
E
I have mine set up as heat extractors. I don't have any pics of it tho
FYI:There is plastic behind those little grill things, it's all one solid piece.
~Black 95 Z A4 Convert~
View My Modlist
P t ' s w e b p a g e
View My Modlist
If you pop them off from the back with a screwdriver. (Really easy) You will see that there is still hood behind them. If you wanted them open then you would have to cut the openings out. Even then I would put a grill over it b/c I think it would look like chit w/o one. I just took mine off and painted them white. I will try to dig up a pic.
<font face="Verdana, Arial" size="2">Originally posted by pu12en12g:
</font>
</font>
It's hard to explain and I'll take pics later(hit a deer so my car is not exactly photogenic right now), but think 3000GT VR4...
View My Modlist
View My Modlist
i thought about this, but then i thought of how much water would come in. i have polished valve covers, and when water gets on them and they are hot it etches fast. for this reason i decided not to do it.
95 Sebring Silver Z28-Leather-T Tops-M6-!CAGS-Hurst Billet/Plus (shortened 1.5")-SPEC Stg.III Carbon-MAC STB-BBS Wheels-clear corners-BMR Rad. Cover-BMR TB Plate-BBK U/D Pulley-MBA O/D Alt. pulley-K&N FIPK-polished&descreened MAF-JET fan switch-!TB-Granatelli LCA's Hotchkis APHB-SLP SFC's-BBK headers-!CAT-Cutout-LT4 KM-1.6 RR's-IRS dual valve springs-Flowmaster AT catback-Accel coil-Accel Extreme 9000 wires-1LE DS-Optima 'red-top'-hand polished alternator-polished aluminum valve covers
-->for pics and info of my 2000 monte carlo ss pace car, 1995 z-28, and 67 impala visit my homepage or my webshots.
<font face="Verdana, Arial" size="2">Originally posted by '95 z-28/ '00 montepace:
</font>
</font>
I sure would like to see pics though, if anyone has any.
Thanks!
E
I've got a friend who did that to his 93 Camaro. He did put a wire mesh behind it and it does look good and he hadn't had any water problems with it. It's a daily driver so he has driven it in the rain before. Works well as a heat extractor (when you are sitting still)
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
Audio/Video:
My SS homepage
CAR AUDIO PLANET
Ok I finally have pics up
http://images.cardomain.com/installs...8_342_full.jpg
http://images.cardomain.com/installs...8_343_full.jpg
http://images.cardomain.com/installs...8_344_full.jpg
http://images.cardomain.com/installs...8_345_full.jpg
http://images.cardomain.com/installs...8_346_full.jpg
how'd u do it
Thanks man It's fully reversible. I like trying new stuff. I was pissed because I f'd up my SS hood when I hit a deer,
so when I was worried about engine temps about a month ago.... I tried this setup.
They definately do extract heat with this setup.
I will be posting a guide, but it's fairly simple, just hard to explain without pics to go along with it
pu12en12g have you ever had any problems with rain? And why do you have them lifted from the back? Why didn't you just keep the plastic part flush and cut the opening were the inserts went before (basically so it would look stock except instead of being fake hood scoops they would be real) I'm not bashing what ya did just curious why you did it that way and if it had anything to do with water. Very creative though!
Mark
Mark
poping just the black plastic out doesnt really do much. just blows air into the engine compartment. its too far away from the intake to be made functional. he probable did it that way so the air escapes like cowl hoods do, when u go fast the air goes towardst the back and out the vents. when the little black plastic is out u are just pullin air in the hood when u go fast and none gets out.
