help if you can
help if you can
ok guys my winter prject is almost over. I have one problem the previous owner of my car witch is a 98 camaro 3.8 dented the front end side bumper cover i have 2 new fenders to put on but that dent was still there so i took off the bumper cover un bent all the brackets but the problem is the dent was there so long i guess that its still in the plastic of the cover.Is there away to make it normal? to take the dent out of the plastic while i have the cover off.......?¿?¿ and also thes a crackin the plastic how do i fix that ?
Re: help if you can
It looks like the only option would be to heat up the backside of the bumpercover and try to pop it back out. More than likely though, since it's already cracked, you'll have to buy a new cover.
