Hella FF75 interested. A few questions first.
I've read a couple threads and saw install sites for these. I really like the look. Now, I need to know, what bulbs fit into these lights? Which ones will fit my factory plug? What wattage and bulb type should I use for the factory wiring? (9006, 9007, h7, etc.) What bulb can I run with a relay and where do I get said relay? I won't burn up the lens/housing by using something other than the 55w bulb that comes with it will I? Is the bulb that comes with it adequate for use as a headlight? Should I use a different type of bulb for brights than the dims? I live in deer country and have ruined 2 vehicles due to deer/inadequate lighting. Any advice would be appreciated greatly.
Re: Hella FF75 interested. A few questions first.
The FF75's run an H7 bulb. If you buy the Hella kits they come with relays, wiring harnesses, head lights and bulbs. I've been told you can run up to 130 watt bulbs if you use the hella harness and wire in the relays. I'm only planning on running 100 watt bulbs because people seem to do that regularly. I was running the stock Hella bulbs and my stock wiring harness for a while and they worked fine. I just decided i want 100w bulbs so i installed the Hella harness and am waiting for the bigger bulbs to show up. I'm gonna blind the crap out of people when i get them going.
