headliner
Pretty easy to do, will only take about 1 hour. What you need to do is take off both sun visors (3 phillips in each) then pry off the a pillars, remove the coat hangers on the c post along with the plastic clip around the seat belt which is near the top on the c post.(becarefull very easy to break). the pry the c post down a little bit
Finally take off the over head light near the hatch and carefully pull the headliner it out through the hatch. your done
>>>>>you can get your headliner reupholstered for around 50 bucks.
