Headlights for 96 Z28
Old 11-05-2010, 02:54 AM
jackrat454's Avatar
My 1996 Z28 seems to be burning out headlights. In the 2 years I've owned the car, I've replaced the headlight(s) at least 5 times. There seems to be no pattern to how they burn out. Either left side or right side, it dosen't matter, they just don't seem to last.
At $24 each for Sylvania sealed beam headlights, this is becoming an expensive issue.
Does anyone have a suggestion or know of an upgrade I can swap in? I'd love to upgrade to the newer style headlights for better vision at night.
jackrat454 is offline
Old 11-05-2010, 06:44 AM
fbodyrs96's Avatar
Re: Headlights for 96 Z28
read the stickies man.... https://www.camaroz28.com/forums/sho...d.php?t=761995
fbodyrs96 is offline
Old 11-05-2010, 09:41 AM
Z28SORR's Avatar
Rapid burnout is usually caused by bad grounds or connector corrosion. If you don't fix the problem your "NEW" light may burn out just as fast.
Z28SORR is offline
Old 11-11-2010, 12:22 AM
Shivo's Avatar
I have the same year, but I donot have the OE headlights. you could look into "angel eyes" knock offs. the below photo is my car head on, pm for closer photos.
Shivo is offline
Old 11-11-2010, 11:22 AM
Brangeta's Avatar
Our '95 seems to go through lights particularly fast, one side more than the other. I can't remember which side though or how many lights I've purchased over the years. Definitely give my headlight topic posted above a try, it's a much cheaper replacement method.
Brangeta is offline
Old 11-11-2010, 12:52 PM
n2ceptor's Avatar
Guess I'm lucky... My 93Z has only had a highbeam go out, since 1999...
n2ceptor is offline
Old 11-13-2010, 06:07 PM
19z28camaro02's Avatar
Had a similar issue with mine, but some dielectric grease it there, solved.
19z28camaro02 is offline
94Z28LS1toLT1
02-10-2015 10:19 AM
Injuneer
Advanced Tech
01-15-2015 02:49 PM
CaRParts102
12-06-2014 08:45 AM
12-04-2014 11:56 AM
siguy
11-27-2014 10:07 AM
Quick Reply: Headlights for 96 Z28
