Hatch trim sloppy ugly
Old 08-30-2014, 07:37 AM
Albani's Avatar
I'm going to say it came from the factory this way. Anybody here that can confirm this?
Albani is offline
Old 08-30-2014, 07:39 AM
Albani's Avatar
Re: Hatch trim sloppy ugly
Albani is offline
Old 08-30-2014, 07:40 AM
Albani's Avatar
Albani is offline
Old 08-30-2014, 12:19 PM
Is that a 4th Gen????
I bought my 94 brand new, still have it, and the original hatch seals/weatherstripping (appears to be what you are asking about, not the "trim" strip that is glued on the edge of the glass) are smooth and aligned correctly, as they came from the factory.
Injuneer is offline
Old 08-30-2014, 01:47 PM
Albani's Avatar
Yeah, not the weather stripping. The metal trim around the glass.
Mine is not glued but rather set in place with some type of RTV and they used a lot of it. See in the pictures where it's all over the glass. And yeah, mines a 4th gen. 2002 Z28, came off the line 3 days before they shut down the plant.
Albani is offline
Old 08-30-2014, 02:28 PM
The trim strip on mine is flexible plastic. From the day I bought it, black ooze was coming out from under it.... nothing like the blobs you show. After maybe 8 years the ooze stopped. It came right off with solvent, and I guess eventually it just ran out of the glue under the plastic trim. I have never seen a problem like what you show.
This was a frequently discussed problem 10-15 years ago, but I haven't seen anyone asking about if for a long time.
Injuneer is offline
Old 08-30-2014, 05:50 PM
Albani's Avatar
Plastic trim - yes, mine is too.
Black ozze - yes, that's the stuff.
Mines to thick to get rid of with solvent. I guess I'll cut and trim it off with a razor blade. I can't believe quality control let that pass.
Albani is offline
Old 08-30-2014, 06:43 PM
It didn't look like that when it left the factory. It developed as the car sat in the hot sun - mine spent it's first year in the heat of Southern California. It did not bubble or ooze like that. It was just a rough edge next to the trim. No one would have allowed what you have to leave the factory. That has either been replaced with a sloppy install, or someone managed to ignore it for 12 years and let it get out of hand. All it took to control it was a wipe with solvent every 6 months.
Injuneer is offline
Old 08-30-2014, 07:26 PM
Albani's Avatar
OK, now it makes sense.
I didn't relize the black goop would ooze out over the years.
Thanks Injuneer.
Albani is offline
93 RedBird
11-15-2015 08:24 AM
Hal Fisher
09-30-2015 09:03 PM
cmsmith
09-14-2015 09:25 PM
92_RS_305
09-08-2015 07:47 PM
CARiD
07-07-2015 08:19 AM
Quick Reply: Hatch trim sloppy ugly
