ground fx
Old 03-26-2005, 06:06 PM
steves97z28's Avatar
ground fx
i have the wings west kit on my car and im having a problem with the rear lip peice. the car sat this winter and at some point it fell off. its not completly off just the middle part, the double sided tape that was provided with them it didnt hold. anyone have a solution for this? thanx in advance
steves97z28 is offline
Old 03-26-2005, 06:11 PM
CrabhartZ28's Avatar
Re: ground fx
if you can find some double-sided adhesive foam weatherstripping i'm pretty sure that would help you out. I worked with that stuff recently and man it really sticks.
Just go up to home depot or lowes and look at their adhesives.
CrabhartZ28 is offline
Old 03-26-2005, 06:17 PM
Re: ground fx
ya i was thinking about using contact cement but fear putting that **** on the paint. im gonna ask a few ricers see what they are using.
Old 03-26-2005, 10:28 PM
ProjectCamaro's Avatar
Re: ground fx
That happened on my LT1 as well, I used self tapping screw's and they worked great.
ProjectCamaro is offline
Old 03-27-2005, 12:33 PM
shaxes's Avatar
Re: ground fx
Just take some screws and screw them in, that is what we did on a friend of mines SS side skirts and rear clip so they would stay on. It does help if your car is black because you can get black screws. If not you can fill the holes with fiberglass and have a paint shop touch it up, but you will never get the ground effects off.
shaxes is offline
Old 03-27-2005, 12:47 PM
Re: ground fx
could you possible get me some pics of how you did it? rydhb4life@aol.com
sick looking ride by the way
Old 03-29-2005, 08:17 AM
1-bad-z28's Avatar
Re: ground fx
If you go to napa or most other parts stores get molding tape. It is like rubber double sided tape. This is what holds all your moldings on. You can also use screws on the inside where you don't see them.
1-bad-z28 is offline
95chwagon
10-16-2015 12:24 PM
autoxr166
09-25-2015 04:21 PM
Greg88
09-20-2015 07:14 PM
sleeperZ96BT
09-10-2015 08:01 AM
92_RS_305
09-08-2015 07:47 PM
Quick Reply: ground fx
