ground effects
Old 01-14-2004, 05:50 PM
95zeee28's Avatar
ground effects
hello guys, i was wondering if you guys can give some advice on something, im thinking of bying the " wings west" ground effects 4 piece kit, are they any good ? do you think i should get them or is there a better company out there, or any nicer ones, any advice on this is greatly appreciated, and also are they hard to install, thank you guys.
95zeee28 is offline
Old 01-14-2004, 07:16 PM
FacelessZ's Avatar
A lot of board members have them and if I ever decided to go with gfx I'd definitely get the WW. They're relatively easy to install from the looks of it...
FacelessZ is offline
Old 01-14-2004, 08:17 PM
Buffdaddy's Avatar
The ww are pretty cool, there are also rksport, vizage, and xenon. I like the vizage look and not many people have that look. Installing is easy they come with double sided tape on them. You can either sand the the bottom of your car where the gfx go and let the tape stick to roughened surface or buy epoxy and glue those bastards up their so they never come loose. That 's what I did
Buffdaddy is offline
Old 01-14-2004, 09:04 PM
phrozen's Avatar
Here are some slightly more unique ones that can be found in the U.S. if you're willing to look for 'em.
Top Speed
phrozen is offline
Old 01-14-2004, 10:41 PM
94camarof1's Avatar
I have the F-1 ground effects
94camarof1 is offline
Old 01-16-2004, 01:16 AM
95zeee28's Avatar
thanks guys, i think im going with wingswest , i kinda like them, not too flashy or ricy but i was wondering do the wings west install with double sided tape or you have to screw them on somehow?
95zeee28 is offline
Old 01-16-2004, 05:16 AM
Buffdaddy's Avatar
Epoxy the gfx, I promise it works and its like cement by how good the bond is. Epoxy is found at any auto store and just takes about 5 minutes of holding. I would keep the double sided tape on but you should epoxy some of the groundeffects and leave some with the tape alone. Because the tape holds well at first which will allow the epoxy to get a good hold. I can guarantee that if you just use the tape, it will eventually come loose. My gfx eventually all came loose and so I had to use epoxy, next time I am going to just epoxy at first.
95chwagon
10-16-2015 12:24 PM
autoxr166
09-25-2015 04:21 PM
Greg88
09-20-2015 07:14 PM
sleeperZ96BT
09-10-2015 08:01 AM
92_RS_305
09-08-2015 07:47 PM
Quick Reply: ground effects
