GREAT upgrade for those crappy headlights!! (photos w/ in)
#46
Originally posted by pu12en12g
Well, I have some true 100w H7's right here... I wish I knew the Lumens output tho
You have Hella FF75's right? I am about to put the high beam 90mm housings in (got them Monday). Now that I am on a roll, I am thinking about also replacing the fog lamps with a better driving light. I am thinking of the FF75 (or FF50, I don't remember which one fits on there ) to do that.
BTW, I guess most fo the people on this board think that their lights are crap, this thread already has over 600 views!!!
Sam
#48
Originally posted by silver97Z
Will the H9s fit in the FF75 housings? What kind of wiring would be needed...H9 wiring harness? Where would I find one?
- The H9 bulb is more expensive
- The H7's which fit right in the FF75 with no modification can put out the same wattage and / or lumen rating as the H9
#49
Thanks,
Brian
#50
How about a 360 Modena-ish headlight cover? Not quite similar enough to look ricey or like we're pretending to be something we aren't (ala vette taillights), but enough to make those cheap-looking headlights look more threatening\classy.
If both this and Whistler's rear panel are actually made, then we'll have come a long way in the department of FBody appearance mods.
#52
Originally posted by superal
Are any of the fabricator guys reading this thread? I think it'd be real cool to get rid of the crap headlights and have something different to mount them in.
Here's a few headlight sites:
http://faq.auto.light.tripod.com/
http://www.lighting.philips.com/foru...i?maxmesgs=200
http://www.network54.com/Hide/Forum/216460?it=0
#53
I posted some pics of the high beams, just installed them today. It was actually about the same effort to install those, compared to the lows. I thought it would be easier because of more room available and the lights being smaller. But the fact that it's smaller makes that the bulb connector in the back is just in the opening in the frame, so I had to grind a lot of plastic away to amke room for the connector. (luckily I got a Dremel kit for Christmas ) Now I have to see how they light up the road!
Pics
Sam
Pics
Sam
#54
WOW ! !
Sam,
I just gotta say, that looks 100% improved now with the high beams in place...
Also, it ROCKS that you are taking alot of HIGH quality photos and sharing them man ! ! It makes it ALOT easier for those of us considering this mod.
Anyways, I wish more people took great photos of their installs like that ! !
- pt
Sam,
- pt
#55
WOW ! !
Sam,
- pt
WOW ! !
Sam,
- pt
When I was doing the low beams, I did not take any pics during the install because (as far as I knew then) nobody else had ever put these lights on, so I was just trying to fit them. Then I took some pics afterwards and I remember pretty good what I did because it wasn't that much that needed to be modified. Now with the high beams, I didn't make that mistake and took some pics during the install, now I gotta put some words to describe the whole procedure. Also worth noting is that the mounting frame that needs to be filed to fit the lights is REALLY easy to do with a hand file, it's pretty soft actually. I got a Dremel kit for Christmas that I used for the high beams, and that worked even faster, went through there like butter
Hopefully, I can find some time to write some to put with the pics soon!
Sam
#57
So are the golden metal things just sticking out like that, or have you not screwed them in yet. It looks like there are 2 screws in the low beams and 3 screws in the highs. Is that correct??
And that link to the shop, did you buy em there? I guess that was the kit for the focus, but looks FANTASTICALLY GREAT.
#58
I bought my lights from Susquehanna Motorsports in PA. The lights are called "90mm low/high beam module for custom applications"
If you need more info, just post back here or send an email!
HTH
Sam
#60
Sam has put so much time into this thread and helping out everyone posting here, that we first need to give him a big Thank You, and a roundapplause :clappingsmilie:. So thanks Sam.
Im mailing you cuz I got just a couple more questions.
