good "super white" bulbs for the corners?
Old 11-27-2002, 10:13 PM
W3dgy's Avatar
I have just installed some H.I.D. bulbs in my high and lows, and they look grate. the only problem is that the bulbs in my clear corners look like crap next to them. so if anyone can recomend so "super white" bulbs for the running lights that would be awsome. a part # would be cool to.
W3dgy is offline
Old 12-02-2002, 08:04 AM
94BlackBowtie's Avatar
Look for a good 1157 Hyperwhite LED bulb...I have found quite a few on e-Bay.
94BlackBowtie is offline
Old 12-04-2002, 02:17 PM
MeefZ28's Avatar
Is it 1157 or 3157 for DRL's???
Also, do either/both work the same as stock bulbs as far as functionality-
i.e. brighter during the day, dimmer when parking/headlights are on, and blink when you use your turn signal???
-J
MeefZ28 is offline
Old 12-04-2002, 03:13 PM
JDHarris's Avatar
For the '02's you need 3157 bulbs for the main part, 198's (?) for the side part.
JDHarris is offline
Old 12-04-2002, 04:31 PM
MeefZ28's Avatar
What about 97's???
-J
MeefZ28 is offline
Old 12-04-2002, 05:27 PM
JDHarris's Avatar
For 98-02's you use the 3157 and 198's, I think for the 93-97's its' the 1157 and 198's... Somebody with an earlier Camaro needs to verify that, but I'm pretty sure that's the case.
JDHarris is offline
Old 12-05-2002, 01:37 AM
MeefZ28's Avatar
So just so we're clear:
For a 97, FRONT DRLs, 1157 bulb, right?
-J
MeefZ28 is offline
Old 12-05-2002, 01:41 AM
JDHarris's Avatar
Yes, front for a pre-98 is an 1157 bulb I believe.... you can double check that by simply pulling the bulb out and looking at it. It should be printed on the black plastic base of the bulb. If it's a round base, it's 1157, if it's a rectangular base, it's a 3157.
JDHarris is offline
Old 12-05-2002, 10:11 AM
JSK333's Avatar
On my '95 the front large bulb is the 3157, not the 1157. I imagine it'd be the same for the '97, but better check. Sylvania had it listed as 1157 for my car even though it's wrong. The small turn signal bulb is 194.
I used Eurolite's Xenon bulbs and they look great and have lasted several months so far. There is usually someone selling them on Ebay. I'm going to pick up their Xenon Fusion headlights soon too.
JSK333 is offline
Old 12-05-2002, 04:29 PM
MeefZ28's Avatar
So I go to autozone today and pick up my 1157 bulbs, come home take out my broken bulb... and lo-and-behold, it's a 3157. No biggie- I didnt open the 1157 pack so I'll just swap em. Just read that last message a bit too late. Thanks tho, I'll probably just get some white 3157's from Autozone- not hyperwhite, that way it will cost under $5 instead of $20...
Lata,
J
MeefZ28 is offline
Old 12-05-2002, 07:21 PM
JDHarris's Avatar
Sorry for the misinformation... I wasn't positive about the bulb sizes. Not intentional.
JDHarris is offline
Old 12-06-2002, 01:34 AM
snksknr94's Avatar
I just looked in my Chiltons guide and it has 2397 listed as the front turn signal. I'm in the same boat my front clear corners look like crap now because my headlights and piaa driving lights are so bright! Is there a guide online some place that lists all the bulb numbers for the different bulbs in our cars? The Chiltons has one but I'm not sure how accurate it is.
EDIT: I just went on the Sylvania web site and it lists 2397 as the front turn signal and parking light as well. It also lists the back up light as 1141 as opposed to 1151 which the Chilton guide says. These were the only 2 differences between bulbs I saw.
snksknr94 is offline
Old 12-06-2002, 08:19 AM
Stock replacement is a 2397...an 1157 bulb is a cross-reference. It will work in the socket with no problem. There are lots of bulbs that are cross references. Also, to look up parts quick on the net, I use AutoZone's website...check it out...click me. Just add you car to the list thing or whatever and you can pull up just about every part for it.
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
marineengineer
02-09-2015 03:59 AM
97TA-WS6-Con
02-01-2015 01:01 PM
Fbodfather
25
06-21-2002 04:12 PM
Quick Reply: good "super white" bulbs for the corners?
