gauges
Old 02-23-2005, 09:14 PM
Adam E's Avatar
gauges
(i think this is where this would go?)
hello. i have a 1994 z28 that came with the 110 mph speedometer. i understand that you can swap out the entire gauge cluster in order to get the 150 mph speedometer. is it possible to just get a different speedo gear or something and then a 150 mph overlay? sorry if this topic has been posted about before but i couldnt really find any threads that discussed this. if anyone knows of any or has any advice im open.
thanks a lot,
adam
Adam E is offline
Old 02-23-2005, 10:41 PM
95_LT1_6SPD's Avatar
Re: gauges
The speedometer is electronic and does not use a gear. You can get the hole cluster off ebay for like $50.
95_LT1_6SPD is offline
Old 02-24-2005, 05:08 AM
Adam E's Avatar
Re: gauges
if i swap out the gauge cluster does my odometer get replaced too? if so, is there anyway i can change the new one to read the mileage that mine currently does now?
Adam E is offline
Old 02-25-2005, 05:19 AM
n2oblkz
Guest
Posts: n/a
Re: gauges
The guage cluster contains your odometer and when you change the cluster, you will lose that mileage. I would shy away from trying to have the mileage on the new cluster changed to your old mileage, it could create some problems.
Formula Steve
09-19-2023 08:31 AM
drt
09-27-2015 04:39 PM
RX Speed Works
09-11-2015 03:31 PM
jackpawt883
09-10-2015 08:53 PM
themex2002
09-02-2015 03:47 PM
Quick Reply: gauges
