Gauge Installation
Old 01-22-2011, 08:15 PM
fernjrivero's Avatar
Gauge Installation
Hello all, I recently bought two auto meter gauges for my 95 z28 and I can't find an opening in the firewall to pass the Fuel Pressure line and the Wideband line through. Can anyone suggest a location or guide me as to where to try? I'm also willing to drill through the firewall but I can't find a good location.
fernjrivero is offline
Old 01-22-2011, 08:50 PM
Re: Gauge Installation
The largest opening is the big rubber grommet behind the PCM. See this writeup from Shoebox:
http://shbox.com/fw/Firewall_wire_feed.html
You indicate you are passing a fuel pressure gauge line through the firewall. Hopefully you mean you are passing a wire for an electronic fuel pressure gauge through the firewall. Running a fuel line inside the passenger compartment is not a smart thing to do. NHRA does not permit it. And the high pressure isolator form AutoMeter is not reliable at all.
If you want a location on the driver's side of the firewall, I can post a picture of where I drilled a hole.
Injuneer is online now
Old 01-22-2011, 10:33 PM
Thanks Fred, you were correct, the gauge I have is mechanical; I'll be mounting it somewhere under the hood.
I will place a digital one inside of the cabin, something like:
http://www.aemelectronics.com/fuel-p...to-100-psi-761
Please do post the picture(s) you have, I saw the link that you gave me, I just do not have enough wire for that. I would like to go through the driver side firewall.
Old 01-23-2011, 09:49 AM
Evolution223's Avatar
I drilled a hole in mine, somewhere behind the knee panel under the steering wheel I was able to get a long drill bit in there, it was a real PITA but it came out to the right of the brake cylinder. I only hade to remove the knee panel, to do it.
You might want to buy a long drill bit at lowes if it will help,
Evolution223 is offline
Old 01-23-2011, 10:48 AM
Yeah I have the drill bits. A small cordless drill, but I'm having a PITA with the location of creating a hole, and on how to get the drill into the location I choose.
Old 01-23-2011, 03:28 PM
Look at the black grommet, with the red wire, and a few others going to it:
I drilled the hole from the passenger compartment side. Pull the carpet down, and the hole location is fairly close to the hard rubber piece that holds the top of the carpet, as I recall (I did that 15 years ago.......). Reference the location from the brake pedal, since the location is between the rod from the pedal to the brake booster, and the large harness connector on the firewall.
Old 01-28-2011, 05:44 PM
Thanks Fred. I will drill this weekend!
RUENUF
03-13-2016 03:39 PM
99TransAmWS6
02-12-2015 07:23 PM
97Z28Muscle
02-06-2015 10:44 PM
Collector Car
01-05-2015 10:58 AM
ro2207
12-04-2014 06:18 PM
Quick Reply: Gauge Installation
