Drowning Driver Door!!
Old 11-22-2002, 06:00 PM
kopperhead34's Avatar
Angry Drowning Driver Door!!
I HAVE A '94 Z28 AND THE DRIVER DOOR HAS BEEN ACCUMULATING WATER IN IT... IT NEEDS TO BE DRAINED,, HAS ANYONE EVER DONE THIS BEFORE? I SEE A BOLT ON THE INSIDE OF THE DOOR.. IS THAT THE RIGHT ONE? HOW DO I PREVENT IT FROM HAPPENING AGAIN- WHERE CAN I BUY REPLACEMENT MOLDING? THANKS FOR ANY HELP!! ed
kopperhead34 is offline
Old 11-22-2002, 06:11 PM
ibanez6rg's Avatar
Drill a hole in that sucka!
Actually I don't know, I would just start untightening bolts
ibanez6rg is offline
Old 11-22-2002, 06:16 PM
chuckys95's Avatar
check the drain holes in the bottom of the door, they are probably plugged up with debris (leaves) maybe
chuckys95 is offline
Old 11-22-2002, 06:19 PM
OK, THANKS,, i WASN'T AWARE THERE WAS DRAINS UNDER THERE.. I'LL CHECK NOW.. THANKS AGAIN
Old 11-23-2002, 03:37 AM
chuckys95's Avatar
ed,
did you find' em, if not i could take a pic of the bottom of my door to show you where they are at.
Old 11-23-2002, 12:03 PM
Hi Chuck,, yes, I looked under the door every inch and didnt see any drains it is totally smooth... there is a "petcock" looking thing (for lack of a better word), on the inside of the door that is closest to the fender... could that be where to drain out the water? Thanks for your help ed
dale3in98
02-14-2015 12:18 PM
Brake_L8
01-20-2015 09:44 AM
cmdeshon
Parts Wanted
12-16-2014 07:58 AM
cmdeshon
12-12-2014 10:51 PM
siguy
11-27-2014 10:07 AM
Quick Reply: Drowning Driver Door!!
