Drilling hingest for aftermarket hood
So my SS hood doesn't fit quite perfectly. It needs to be over toward the passenger side like 1/8", and is raised up above the fenders about 1/8" on each side. I've read this is very common and that all I really need to do is drill out the holes in the hinges so that I'm able to give it some more play.
Which hinges are you guys talking about drilling out?
And it fits perfect up front. Lines up with the bumper just fine, and I have my rubber mounts adjusted OK. The only problem is on the sides.
Was it labeled as a direct replacement? If so send it back and demand they pay the shipping charges.
The last thing you want to do is start drilling holes and voiding their warranty or product reliability.
But if it's off ALOT and they are a reputable company (not eBay) than you MITE have a chance of sending it back.
I wouldn't say it's off a lot. It's probably off about as much as any other aftermarket fiberglass hood.
I'm not going to drill in the hood. I'm assuming I drill the hinges that are bolted to the hood?
???? You only have two hood hinges, so I'm a little confused. What other hinges would you drill? Anyway the hinges should already have slots that allow you to adjust the hood relative to the hinges. If you need more adjustment you can increase the length/size of these holes by drilling or grinding them larger. You may also need to adjust the fenders, they too should have slotted holes and/or shims that allow some adjustment.
If your factory hood fit fine dont go adjusting the fenders (not that you even can adjust the fenders from side to side) If it fits up front and the sides are off make the whole bigger on the hinges from left to right.To get the hood down in the back you need to elongate the wholes on the hinges that bolt to the car not where they bolt to the hood.There are 3 bolts that atatch them.If you need ne help let me know and i can send you pics of my hinges.
swoeman815@hotmail.com
Ok, so the hinges are not the problem. The hood looks great aside from being up about 1/8" higher than the fenders.
The problem is, I'm hitting the plastic radiator cover with the belt diagram. So I pulled that, and it fit much better, but not quite perfect. So I pulled the radiator cap. Now it sits perfect on that side, but the other side is hitting the top of my cold air intake.
So the problem is the clearance on the hood. My hood is an actual ram air with the ducts, and the tunnels are hitting.
If anybody has had this problem, what'd you do to fix it?
If I am going to pay $500+ for something, it better bolt right up and fit without any problems. I understand those rubber spacers would probably need to be adjusted, but thats it. No drilling new holes or having to modify it to make it look right. Thats just my opinion though.I work too hard for my money to just throw it away on junk.
Apparently the OP figured out his problem and didnt have to drill new holes. Im glad for you man, because if that was the case I would have been sending it back. Im not too sure about your other problems, but if it comes to you having to hack and chop the hood to make it fit, send it back for a replacement, and make them pay the shipping.
I understand that, but my point is I shouldnt have to start drilling new holes and wasting a lot of my time to get it to work. Just like anything aftermarket, there is going to be a margin of error.
07-10-2015 02:23 PM
