Direct replacement white bulbs
Old 08-20-2003, 12:56 AM
Indy93Z28's Avatar
I was wondering if there's any company that makes direct replacement bulbs for 93-97 style Camaros. I'm looking for white bulbs for my headlights and foglights but I don't want to change the stock housing cause well I like the stock look just not the yellow light. I don't want a ricer style purple or blue tint. Just clean white
Any help would be appreciated
Indy93Z28 is offline
Old 08-20-2003, 07:20 AM
teke184's Avatar
Sylvania SilverStars...they are awesome
bout $50 a pair, 9005 and 9006 is what you want, dont' recall which one was the hi and which the low but those are the ones
i think Jegs still sells them
you jsut pry out the bulb part of your old sealed beam, and epoxy in the new bulb...boom you're done
teke184 is offline
Old 08-20-2003, 11:36 AM
Indy93Z28's Avatar
What about for the fog lights? I don't see the point of having white bulbs in the headlights w/o having them in the fogs too.
Old 08-20-2003, 01:09 PM
94BlackBowtie's Avatar
For the fog's try a search on MSN or Google for "White 885 Bulbs" or "Hyperwhite 885 Bulbs" and choose your liking. There aren't a whole lot out there for the stock fog's - but they are around. Autooptiks.com also sells some.
94BlackBowtie is offline
Old 08-20-2003, 03:23 PM
Indy93Z28's Avatar
Thanks! I think I found some made my Nokya. It shows ricers in the pics but the white seems to be clear white. Any thoughts on those?
Linky
Old 08-20-2003, 04:47 PM
Those are good bulbs Nokya is one of the best. Just get the 893 - it is a direct cross reference that has the same style connection (straight on rather than 90*).
With those and the Silverstars you will be set.
Old 08-21-2003, 01:07 AM
Indy93Z28's Avatar
If you look down at the part #s it says they have the 885s... that's what I need right?
Old 08-21-2003, 06:24 AM
It says "Manufactory part no:" - meaning they only have the cross reference's for those bulbs - or "the 893 will fit these manufacturer part no's." Also note - "Product Name: Nokya Arctic White 893 37.5W Twin Pack Light Bulbs
Description: Twin Bulb Pack 893 Arctic White Auto Foglight Light"
Those will fit fine - but it is not actually an 885.
In their picture it also shows an 894 - and a lot of websites will pass that off as a cross reference as well, even though it has a 90* base on it.
Old 08-21-2003, 12:37 PM
Indy93Z28's Avatar
Oh ok I understand now. Thanks for all your help. I'll post the difference once I order everything
Old 08-21-2003, 05:12 PM
MadMaxz28's Avatar
i put clear turn signal lens in and wanted to replace the old bulbes with bright white ones. but which ones? thanks
MadMaxz28 is offline
Old 08-21-2003, 05:44 PM
You need some white 194 bulbs (that's the little ones) and some white 1157 bulbs - 1157 is a cross reference to 2397 which is the stock bulb size - they aren't available in white. Do a search on that site that Indy is buying his from, or search MSN and Google for those same terms I listed above - just different sizes.
squarehead
01-15-2015 07:02 PM
ANDYZ28
12-29-2014 09:13 PM
jim88iroc305
08-13-2002 09:24 PM
30thZ286speed
08-03-2002 04:54 AM
Quick Reply: Direct replacement white bulbs
