Differences in wheels.
Old 02-01-2004, 01:54 PM
nothingeined's Avatar
Well I went yesterday to pick up my SS rims, but needless to say the tires ended up being low profile tires. I forgot the exact brand, but I remember them saying F1 on them. Any bump I hit would throw my vehicle off way bad. I would be doing 50, small bump and the whole car would swerve. The day before I had the allignment done, tires balanced and mounted on my 16's. So the whole way up I had no problems. Switched and then the swerving occured. Is it the low profile tires doing this?? I had to pass on the deal because I didn't feel like swerving all over going 70 on the way home. Are there any 17 inch tires that will not do this?? I want to get the SS rims sooo bad. But if I can't find a decent tire that will not swerve, them I'm out of luck. Don't have to be low profile or anything, just for it to fit and give a decent ride like my stock ones. Price not high, but I can afford decent ones. Any ideas?? Thanks a lot!
nothingeined is offline
Old 02-01-2004, 03:31 PM
Zack's Avatar
you went from a 245 tire to a 275. thats a lot more rubber making contact with the ground, so that causes more movement. my wheel moves when I go over bumps and when i brake
Zack is offline
Old 02-01-2004, 05:50 PM
Marky82's Avatar
mine did the samething when I went from 245's to 275's...I think its called "tramling" or something like that. My car pulls alittle when i brake and if i'm driving on part of a road that is slightly uneven.
Marky82 is offline
Old 02-01-2004, 07:40 PM
So there is nothing I can do???
Old 02-01-2004, 08:23 PM
95_LT1_6SPD's Avatar
wait until you get your car in the grooves in an old road
95_LT1_6SPD is offline
Old 02-01-2004, 08:48 PM
J96Z's Avatar
thats the trade off you make when you go to wider low profile tires. They hold the road and handle better but they also like to grab every groove on the road and pull you around. Breaking was real fun back when I had my stock brakes with warped front rotors. I had to make sure i had a good hold on the wheel if I had to slam on the brakes. Id be pulled into the next lan if i wasnt paying attention.
J96Z is offline
Old 02-01-2004, 09:06 PM
So there are no regular tires I could get without the pulling and shaking Don't have to be low profile or anything. Just as long as they fit. If a normal SS came with these rims brand new with the stock tires, do they experience this???
Old 02-01-2004, 09:09 PM
Jilly's Avatar
Aaaah, I never knew that. I went from 255s to 275s recently and have noticed the same thing happening.
Jilly is offline
Old 02-01-2004, 09:11 PM
Were your 255's on 17 inch rims Jilly if you don't mind me asking. Or were they on 16's? Thanks!
Old 02-01-2004, 09:20 PM
Zack's Avatar
it has nothing to do with the tire brand etc, its all in the width of it because it makes more road contact. you get used to it
Zack is offline
Old 02-01-2004, 09:24 PM
Jilly's Avatar
Yeah, they were on 17s.
Jilly is offline
Old 02-01-2004, 09:30 PM
Were you having the same problems as I mentioned on my first post, or was it just normal driving?? Thanks again. Also, does lowering the pressure them, say 28 psi, make a difference in anything?? I appreciate everybodies help
Old 02-01-2004, 09:37 PM
Jilly's Avatar
Yes, the exact same thing was/is happening to me. I thought maybe it was because my alignment was off. I still think that might be it, but what you described sounds just like what my car is doing.
I have no idea about what lowering the pressure would do.
Jilly is offline
Old 02-01-2004, 10:01 PM
lowering the pressure wont do anything to help with this. it is just the width of the tire grabbing the road better and getting into ruts and grooves more/ the lower profile making the ride harsh.
Old 02-01-2004, 10:03 PM
Oh well. Thanks a lot everybody! I learn something new everyday.
Quick Reply: Differences in wheels.
