cutting springs ?
I cut mine before i got airbags and it lowered it alot but it was to low up front and it made my wheels angle a little but when i drag raced on the streets i could not do it on a bumpie road because the car was really really bouncie i would never tell some one to do it just get bags and adjust it
I've cut a few sets of stockers for friends with no adverse effects.
Just use a cutoff wheel instead of a torch and you'll be fine.
Cut 1 coil from fronts and 1.25 coils from rear for around 1 inch drop.
Cut 1.5 coils from front and 2 from rear for the same effect as a Eibach sportline.
Originally posted by AW/whiteZ-28
The reason it sits higher is so when you sit in it, it will level out
Well instead of thinking that it won't work and leaving it at that get someone to look while you are sitting in the car and be sure about it
10-31-2016 11:09 AM
Lt1son
12-31-2014 01:35 PM
