Crusty 4th gen headlights (pics)
So, my older camaro had crusty headlights, and I did some research and tried to find some ways to clean them, but unfortunately, nothing worked.
But this time around, my lights weren't as crusty, and I actually had some *decent* results, but I'm going to play around with more stuff tomorrow.
before:
after:
all I used was meguiars clear plastic cleaner and polish.
buffed on and buffed off about 4 coats of cleaner then 2 coats of polish. Not really like new, but a pretty big improvement.
I want to try mothers aluminum polish after I sand them down with 2000 grit sandpaper, but I dont know if I want to risk ruining them or not because I have this gut feeling they are going to just get cloudy.
before:
after:
The idea of sanding them makes me nervous too. I've had people tell me to clean our CME with steel wool and I'm not dumb enough to try it. Steel wool on polished cast aluminum? Not a good idea IMO....
I'd try everything before getting out the sand paper bro.
well, I tried coating them in aluminum polish and buffing it out, and it really smoothed out the surface, so I'm thinking I can sand off all the crusted crap, then smooth it all with the aluminum polish and then seal it with the plastic polish.
only thing is, I don't know how long those polished fibers are going to stay on my headlights.
Mine were crusty, yellowed. I heard about the 2000 grit and the plastic
polish so I did one of them to see. It works! Polishing alone will work if you
can take enough material off. Toothpaste might also work. Basically you
are removing the outer baked plastic. I used 1500 paper, and then 2000 to
smooth it out. Washed well, dried and polished.
Before:
After sanding, but before polish :
I dont have the after polishing pictures up on my FTP yet. Sorry.
Tom
Before:
Tom
Before:
Tom
Before:
Tom
I was wanting to clean mine up too. I tried wet sanding with 2000 grit and it came out worse then they started. I tried toothpaste...it worked ok, but they were still cloudy. I have looked for answers and found several kits you can buy that are supposed to clean it up.
I am thinking about getting this, but just dont know if it is worth the money yet....
http://www.autogeek.net/plastik-lens-cleaning.html
I tried toothpaste, did nothing once they dried.
heres everything I've tried:
meguiars plastic cleaner
meguiars plastic polish
meguiars scratch X
toothpaste
wetsanding (old headlights, thank god I dont have them anymore )
and none of those have lasted longer than 30 minutes.
I'm going to try and find 3 step novus next.
meguiars scratch X
toothpaste
what he said, its chips, bug guts, and weather wear. sand it and polish it with a cutting compound. its not going to hurt anything. people do this with paint (wetsanding, color sanding) so trust me it will be fine with plastic.
meguiars scratch X
toothpaste
meguiars scratch X
toothpaste
if there is moisture on the inside of the lense you can drill a SMALL hole on the bottom of the lense and it will get rid of it once you run the lights for a while.
