COLORED interior dome light
Old 09-16-2002, 03:40 PM
anasazi's Avatar
has anyone figured out a good way of making your interior dome lights colored? i once used a high temp lightbulb paint and it burned off because of the heat from that long bulb in the roof. has anyone found anyplace that sells already colored bulbs that don't eventually turn brown or burn up?
i'm specifically looking for blue
anasazi is offline
Old 09-16-2002, 03:54 PM
02T-Camaro's Avatar
I would like to know too?
02T-Camaro is offline
Old 09-16-2002, 04:10 PM
Black_Z28's Avatar
I did have a picture of my interior but I can't find it. Its red now. What I did was buy some transparent spray paint, and spray the clear plastic. Worked out great. I've had it like that for about a year now without any fading or any problems. Also you can put as many coats on as you want, which is what makes it darker or lighter. I'll try to find the picture.
Black_Z28 is offline
Old 09-16-2002, 05:35 PM
iowacamaro019's Avatar
TTT
iowacamaro019 is offline
Old 09-16-2002, 08:33 PM
AW/whiteZ-28's Avatar
GET...
hyper whites thats as close as you can get to blue without it
turning to aqua im getting some tommorow make sure you dont get pepboys brand though they turn brown go to a import shop try and find xenon bulbs
AW/whiteZ-28 is offline
Old 09-17-2002, 09:14 AM
anasazi's Avatar
how much do those cost? and how much brighter are they?
i've got a little sheet of blue theatrical gell that i used to color the light but its always seemed too dark... and i'd like a reversable method (ie not spray painting) in case it gets old.
anasazi is offline
Old 09-17-2002, 09:57 AM
catsnet's Avatar
that's what I use
Dome light
catsnet is offline
Old 09-17-2002, 12:39 PM
anasazi's Avatar
Originally posted by catsnet
that's what I use
Dome light
how does that fit into our dome light housing?
anasazi is offline
Old 09-17-2002, 03:53 PM
catsnet's Avatar
for the rear one you just push 2 housings a little more towards each other and push the bulb in. i have this bulb in there for more then half a year and it never moved
for the mirror you just push them in since they have 4 housings (2 at each side of the bulb)
catsnet is offline
01-23-2015 01:13 PM
12-04-2014 11:56 AM
siguy
11-27-2014 10:07 AM
racer08
08-12-2002 05:44 PM
Quick Reply: COLORED interior dome light
