Clear Side Marker Install??
Old 05-22-2003, 11:11 AM
Knowklew's Avatar
Question Clear Side Marker Install??
I just got my new clear side markers for the Z28 and i have no idea how to install them....Anyone wanna shed some light for me?
Knowklew is offline
Old 05-22-2003, 11:17 AM
94BlackBowtie's Avatar
Pretty Simple -
•First, just pull the 10mm headed bolts that hold on the underbody piece of the fender area. It may also help to pull the three little pins that hold the center of the front end piece on underneath. In short - just get access to the markers from the underside/inside.
•Go ahead and twist out the bulbs by their bases.
•There are three bolts/screws that hold on the corner markers. Take these out, and you are ready to pull it out.
•Stick the clear corner up in there, and tighten down the three screws.
•Twist the bulbs back in.
•Put the underside of your car back together.
Note: It isn't necessary to remove the air dam (long plastic piece that runs across the underside). You may want to remove the bolt on the end for a little easier access.
Good luck - shouldn't take no time.
94BlackBowtie is offline
Old 05-22-2003, 11:19 AM
Knowklew's Avatar
I am talking about the fronts....
Knowklew is offline
Old 05-22-2003, 11:29 AM
Look up.
Old 05-22-2003, 12:05 PM
Koors96Z's Avatar
I heard for the LS1 body style, its easier to take off the headlight and go in from the top. I dont exactly know how, hopefully someone with an LS1 can explain better.
Koors96Z is offline
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
slocody
02-10-2003 01:04 PM
RedLineRev
01-23-2003 03:51 PM
Quick Reply: Clear Side Marker Install??
