Changing headlight bulbs
Old 07-30-2006, 11:30 PM
CamaroRacing12's Avatar
hey agian guys so one of my headlight bulbs went....so i went to take it apart and i got the whole light off but can't get the bulb out....is their any special way to twist it open and off of the lense or is mine just bein fussy?.....just wonderin if everyones was like that or just mine
CamaroRacing12 is offline
Old 07-31-2006, 12:57 AM
LT1 POWR's Avatar
Re: Changing headlight bulbs
Im pretty sure stock LT1 Camaro headlights are sealed beam so there is some sort of adhesive sealing the bulb to the lense. What i did was take a razor blade to the adhesive to remove the stock bulb, then i sealed them back up with some JB weld. A high temp silicone will work also.
LT1 POWR is offline
Old 07-31-2006, 01:36 AM
Rashiki's Avatar
Careful heating of the adhesive with a propane torch will also help to ease removing the bulb.
Rashiki is offline
silvermansteve
03-04-2015 05:02 PM
94Z28LS1toLT1
02-10-2015 10:19 AM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: Changing headlight bulbs
