Changing camaro rear to firebird one?
My friend has a 96 camaro, and was wondering if he could swap out his rear end for a firebirds one? Or at least, the doors or something? He likes the curve the door has.
Thanks! There is no apperance section, and camarov6.com will not work for me
There is an apperance section here. Its just below the lounge. You could try posting the post in there too. Theres alot more posting done in there than the v6 forum. Im not sure that changing the doors would look too good unless you change the front and rear quarter pannles as well. Im sure its possible to do. The doors should be the same in demension length and height wise. Im not sure if there the same width.
Brian
Brian
07-04-2005 05:00 PM
