Can i put z06 wheels on my car?
Old 08-09-2003, 09:17 AM
IrocinthatZ's Avatar
Question Can i put z06 wheels on my car?
Hi all i have a 1989 Iroc-Z with the stocker 16" rims. I wanna put the 17" 10 spoke zo6 rims on it but im not sure if they will fit, just curious...
thanks
James
IrocinthatZ is offline
Old 08-09-2003, 10:59 AM
ROADRAGE's Avatar
not without huge spacers, and they still wont fit the way they should
ROADRAGE is offline
Old 08-09-2003, 04:45 PM
that sucks what would be the nessary modifications that i would need to perform in order to get them to fit properly??
thanks
James
Old 08-10-2003, 02:28 AM
chuckys95's Avatar
thanks
James
ANSWER
chuckys95 is offline
Old 08-11-2003, 12:35 PM
Z28SORR's Avatar
You can also swap rear ends from a late model. It will fit and give you the proper axle length for those wheels.
Z28SORR is offline
Old 08-11-2003, 07:12 PM
Yeah i forgot to mention that i have a dana 44 rear end. I got it about two years ago from SLP performance.. Will the rims fit up to it?
thanks
Old 08-13-2003, 09:50 PM
ttt
Old 08-14-2003, 02:52 PM
Z28SORR's Avatar
The differential width, from flange to flange, of the 3 gen. is narrower than the 4th gen. So if the dana 44 was built for your car you will have the same problem. The 4th gen. wheels will rub/hit the insides of the wheel well. The only way you can make this work is the big spacers and this is not recommended.
Z28SORR is offline
Old 08-14-2003, 02:54 PM
pu12en12g's Avatar
SPD makes billet adapters that would work.
http://www.skulte.com/adapters.html
pu12en12g is offline
hotrodyou1
12-20-2014 10:05 PM
ChrisFrez
12-07-2014 06:01 PM
ro2207
12-04-2014 06:18 PM
USAirman93
11-24-2014 03:37 PM
regular Joe
08-08-2002 07:53 AM
Quick Reply: Can i put z06 wheels on my car?
