camaro gauges in a t/a?
Old 07-17-2006, 09:14 AM
scott5's Avatar
I was wondering if you can put camaro z28 gauges out of a 95 and put them into a 95 trans am? Can you do this or what?
scott5 is offline
Old 07-17-2006, 09:24 AM
Honda Hunter's Avatar
Re: camaro gauges in a t/a?
No.
Honda Hunter is offline
Old 07-17-2006, 10:03 AM
Blue96z28's Avatar
naw, they are different physical sizes. you could put a 97 camaro cluster in a 95 bird though....
Blue96z28 is offline
Old 07-17-2006, 10:05 AM
Only the non digital I think.
Old 07-17-2006, 10:18 AM
Blue96z28's Avatar
I was told either works as long as its still 97 for the LT1 calib. tach....about to find out for sure I guess, since I got some digital 97s going in my 96 this week.........
Old 07-17-2006, 11:01 AM
94Z28WP's Avatar
'97 digital works with 93-96 wiring... 98+ doesn't.
94Z28WP is offline
Old 07-17-2006, 11:17 AM
You mean with 93-96 birds correct?
Old 07-17-2006, 07:31 PM
SantaCruz163's Avatar
Trans Am gauges look better than Camaro gauges, why would you want to switch?
SantaCruz163 is offline
Old 07-19-2006, 10:19 AM
scott5's Avatar
I gues it would just take time to get used to but all i have owned was camaros and i just got used to the look of the gauges. So what i read i think i understand that a 97 camaro cluster would fit in my formula? And it doesnt matter if its a digital or not?
scott5 is offline
Old 07-19-2006, 12:04 PM
Blue96z28's Avatar
Yes thats 100% correct. I personally like maro gauges better than firebird ones as well, the bird-t/a gauges have that nasty red that gets SOOO old IMO.
EDIT: forgot to mention, you'll probably have to change the plug wiring, no cutting or anything, just remove some pins and insert in a new connector, but there are many guides on here with the pin-outs....so its not to bad.
Old 07-19-2006, 12:29 PM
A member here has a diagrahm of the pins and such on cardomain
Garcia5
07-07-2022 06:51 PM
Red Hawk 94
03-18-2019 04:03 PM
Collector Car
01-05-2015 10:58 AM
CaRParts102
12-06-2014 08:45 AM
slothgrant
08-22-2002 03:01 PM
Quick Reply: camaro gauges in a t/a?
