Anyone use these headlights?
http://astore.amazon.com/camaroz28com/images/B001FBMA7O
In the product description it says they are fog lights, are they or are they lowbeams ? Anyone use them on their car? Was there a change in the head/fog lights from '94 to '95...I bought the sylvania silver star bubls and was going to do the bulb replacement with my headlights, but if these would work, would be brighter, and are truly "plug and play" like it says, I may go with them...Just looking for some info.
Re: Anyone use these headlights?
Update:
Found a couple variations of these bulbs
http://astore.amazon.com/camaroz28com/images/B003LEHDTI
Anyone have experience with the xenon bulbs? I am not looking for anything super bright, but want to go better than my stockers....Also, anyone ever have a problem with legality? Don't know if a 6000k or 8500k as my low beams may be too bright for TX...
The first one is a fog light -- it says it's an 880 right on it. Unfortunately, you need an 885 for a '93-97.
The second one just says it's a low beam, and doesn't specify the bulb type. It might be correct for a '98-02, which uses the 9006 bulb (which looks a lot like the one pictured), but a 93-97 requires the H4351 sealed beam light, which looks completely different.
Next time you're posting links to Amazon, link to the item page and not directly to the image. It might let us be more helpful.
actually I just replaced two low beams on my 96 z28 and you use 9006 for those also.. there is a sticky post on how to change just the bulbs on a 93-97 camaro.. was very helpful and mine work great
Thanks for the help
jackpawt883
09-10-2015 08:53 PM
08-17-2015 09:50 AM
Henson071
08-04-2015 09:32 AM
