Any tips with por-15
Mine should be here any day now.....ordered all the prep stuff and the small cans.
This is my project http://web.camaross.com/forums/showthread.php?t=538664
I may also do a few other small things, just wondering if there is anything I should know. If I like it I may also do my cage in it.
Just clean it up and paint it on. Don't use your expensive brushes either, you might as well get some cheap-o brushes that you don't ever plan on using again. Don't leave the POR-15 open for extended periods of time either. It will harden up and be unusable. Of course, that's like any paint.
Clean surface and as mentioned above cheap brushes and where gloves cuz its fun getting it off your skin to..o and I would put it in a plastic cup instead of the can it comes in unless u dont get any where the top goes..cuz u will destroy the can tryin to get it back off...good luck..its great stuff
make sure that after you open it for the first time, you wipe off the bottom of the lid, all areas of it. I did not do that, and well, I had to basically cut the lid off and pour contents into a new can. Also, make sure you dont get any, none, nada into the groove the lid goes in.
Which did you get? if you got the semi-gloss, make sure you stir it up really well, like for 15 minutes or so. It will look all sweet and shiny wet when you put it on, but if you did not stir it enough, it dries all streaky
When you reseal the lid, follow the directions, and put a plastic baggy between the lid and can, or you will never get the lid off,. Wear some gloves, it will stay on your hands a looooong time.
I used a tupperware plastic container, and after it dried it peeled right off.
autoxr166
09-25-2015 04:21 PM
colts0455
09-02-2015 12:41 PM
