Am I Going Crazy..?
Am I Going Crazy..?
I know this isn't really appearance, but there isn't an "interior" forum.
..I was driving home tonight, and i went to flip on the map light in the bottom of the mirror for the drivers side, and it wouldn't come on, so i'm thinking, great a dead bulb, so i flip the one on the passenger side and it came on. I reached over the turned on the dome light from the dash switch, and they both came on. So i'm like hmm.. So after i get home, i pull up in the driveway and park, and flip the switch on the mirror, and sure enough it comes on, so i put it in reverse, and it won't come on. Am i crazy, or did GM go through alot of trouble to keep me from turning on the light? It just doesn't make sense. I don't have an owners manual, so i can't look and see if its supposed to be this way. Has anyone else noticed this?
Also on a seperate tangent, the light on the dash for the parking brake, doesn't light up anyone when i pull up the brake, but when i start the car and all the lights run the diagnotic test on the dash, it does come on. Its obvious when i park in the driveway that the brake works, i'm just wondering whats wrong, and how i should fix it.
Thanks, y'all..
[yes i'm from the south].
Thanks, y'all..
maybe the driverside lamp has something to do with saftey? if its in a certain gear it wont work or something. what year is your car? i knwo my 93 doesnt do this though. as for the brake light i think theres a sensor when you take the centre console apart, at the parking brake lever.
I think you are just going crazy - or your car is one.
You might want to just check the wiring out where you can get to it - see if there's something rubbing something else (at the connections, etc.) The console are would be a good place to start. Easiest way to get into it (in case you don't know) is just pop off the shifter **** and pull the cover off.
jcamere94z28
15
01-17-2013 02:05 PM
camarosource
13
11-25-2008 02:27 AM
