93-97 Firebird - brighter than stock headlights?
Old 07-20-2007, 01:47 AM
got_hp?'s Avatar
what are my options for getting some brighter than typical headlights that are direct replacement in a 93-97 bird?
not interested in all the hassle/cost of HID's, just something thats an upgrade from the standard crappy headlight.
i ran a search but theres seems to be a ton of stuff out there with differeing opinions, was hoping someone could just narrow it down a bit for me.
got_hp? is offline
Old 07-20-2007, 03:57 AM
BlackbirdWS6's Avatar
well if you wanna go very very simple, pick up some silverstar replacements from pep boys or whoever. If you want better than that with a little more hassle, convert the sealed beams to some hella 165mm H4 housings and quality h4 lamps. I picked up a whole set with adapters, housings, and lamps for ~100 bucks but well worth the money before I went to HIDs. I have pics if interested.
-Brian
BlackbirdWS6 is offline
Old 07-23-2007, 01:22 AM
IdahoLT1's Avatar
The silverstars are probably the easiest ones to get. They are pretty bright.
IdahoLT1 is offline
Old 07-23-2007, 01:26 AM
IdahoLT1's Avatar
Heres a link http://www.partsamerica.com/ProductD...pe=301&PTSet=A
They, IMO are the brightest ones available. The cool blue ones arent as bright but aesthetically look better and 2x the price. And the part # is H4666ST. I believe autozone, pep boys, napa etc. all use the same part number.
IdahoLT1 is offline
Old 07-23-2007, 09:28 AM
The Captain's Avatar
do they make the sliverstars for the fog lamps as well?
The Captain is offline
Old 07-23-2007, 10:39 AM
yea, 880ST bulbs. Silverstars are the easiest and look ok but replacing the housing with a much better one is the best way to go in my opinion. Silver star headlamps and foglights will run you ~$85+ whereas for another $50 you could have much better headlight housings with the silverstar fogs.
and those same housings with HIDs, clear corners with LEDs and new angel eye fogs as well.
-Brian
canbaufo
05-25-2015 12:01 PM
MyShibbyZ28
02-14-2015 12:05 PM
LT14LIFE
02-09-2015 09:35 PM
Brake_L8
01-20-2015 09:44 AM
CaRParts102
12-06-2014 08:45 AM
Quick Reply: 93-97 Firebird - brighter than stock headlights?
