255/35/18 on 18x8's?
Thoughts, suggestions, anything?
Will it work, is it not recommended for some reason, is there going to be rubbing, etc.???
Car the wheels are going to end up on is not lowered as of yet, but probably will be. They are on a lowered car currently with 245/40's and all is well.
Anything you can tell me is appreciated - thanks guys.
Thanks AW - I have heard stories similar to what you are talking about - so I'm not too worried about the back really -
Main thing I am wondering is if a 255 will be fine on a 8" rim, and about the fronts rubbing under hard turning. Was thinking surely someone would know for sure???
They recommend 8.5 to 10 inch rims for the 255/35/18s.
That being said, It would work just fine. You may get slightly more bulge out of it, but there are people around here putting 315s on 9 inch rims!!!
Honestly I don't think you will have a problem at all.
Hey,i have 255/35/18's on my car in the front on an 8 inch rim with 5.5 inch backspacing,lowered 1.5 inches and i have no rub at all at any time,so you should be fine!!!
my sig
Centerline 18x8,18x9.5 wheels,255/35/18,285/35/18 Dunlop tires, Arizona Speed & Marine cold air,mass air sensor,March pulleys,Borla cat back,Hypertech programmer,Mac springs,KYB adjustable shocks,BMR stb,clear corners,clear headlight covers,MAF sensor,BBK throttle body,harwood ram air hood/carbon fiber insert,carbon fiber 69 style Z28 badges,shaved rear panel,no cats,hella FF75 headlight conversion,mesh grille insert,hockey stick stripes,
my sig
