18x10.5 with 7.5 backspacing
You could compare it to a 17x11 GS offet wheel (7.93" backspace, 4.00" frontspace).... you will have about 0.40" less backspace, so there shouldn't be any interferences on the inside fender liner, and you will have about 0.10" less "frontspace", so the wheel is going to be placed pretty much where the 11" wide GS offset wheel sits. I'm figuring the rims you're looking at have a 46mm offset, and that's just about right. As long as you like having the rims/tires just under the fender outline when you look straight down from on top of the fender.
Moshbmx1
01-20-2015 03:27 PM
Kain
12-31-2002 05:34 PM
JasonD
10-14-2002 08:30 PM
