Guaging Interest - Kenwood KAC-7201 800W amp/ 2 Kenwood 12" Typhoon Subs
As stated in the title, i'm guaging interest at this point. I have this stereo equipment that I took out of my third gen, wanting to put in my fourth gen. I've decided, however, that I don't want to take up the trunk space in my fourth gen, so im deciding whether or not to sell.
These are the specs on the amp - it runs for about $150 - $175.
* Cast Aluminum Heat Sink: with Sandblast Finish
* Power Indicator: Blue Logo Triangle
* Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
* Maximum Output Power (Bridged):800 Watts
* Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 230 Watts x 2
* Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2
* 2 or 1 Channels of Amplification
* High-Pass Electronic Crossover: 150Hz, 12dB/oct (Switchable)
* Ground Isolation Circuit
* Input Selector: AB/A (Common)
* Quiet Turn-On
* RCA Audio Inputs: Gold-Plated
* RCA Line Outputs: Gold-Plated
* Speaker Connectors: Gold-Plated, Screw-Type
* Speaker Level Input Terminals: Plug-Type
* Stereo, Left + Right, Mono, or Tri-Mode Operation
* Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
* Bass Boost: Off/+12dB (90Hz)
* 2-Ohm Stable
* Copper EE-Core Power Transformer
* Noise Supression Filter: Toroidal
* Power Input Terminals: Gold-Plated, Large Screw-Type
* Power MOSFET Switching Power Supply
* Power Supply Fuse: 40A
* Secondary Capacitors: 2
The 2 Kenwood KFC - W3009 Typhoon 12" subs run between $80 - $90. Specs:
Key Features
* Double Magnet Construction
* Double Spider
* Frequency Response: 25Hz - 800Hz
* Impedance: 4 ohms
* One-Piece Cone Design: with Red Metallic Center Emblem
* Pearl Mica Injection-Molded Polypropylene Cone: 12" Typhoon-Type
* Power Handling: 800 Watts Peak
Woofer Features
* Double Spider
* Impedance: 4 ohms
* Magnet Weight: 63.4 oz
* Power Range: 35-400 Watts RMS
* Sensitivity: 93dB
* Speaker Connectors: Gold-Plated, 2-Way SB-Type
* Urethane Surround: with Perpindicular Inner Wall
* Vented Voice Coil: 2-Layer
* Top Mount Depth: 5-5/16"
Specifications:
Thiele-Small Parameters
* DC Resistance (Re)
* Electrical Q Factor (Qes)
* Force Factor (Bl)
* Mechanical Q Factor (Qms)
* Moving Mass (Mms)
* Peak Excursion (Xmax)
* Resonant Frequency (Fs)
* Total Q Factor (Qts)
* Voice Coil Diameter (d)
* Volume Acoustic Compliance (Vas)
This combo was only in my hatch for about 3 months, never abused, and work like new. If I decide to sell, I would like to see $220 + shipping, negotiable depending on your location. They would ship in original packaging, three seperate boxes. If anyone would be interested in this, please either post here, pm me, or both. Thanks!
See the items listed here: http://www.actofmercy.com/unrelated%...es/subsamp.jpg
* Quiet Turn-On
* 2-Ohm Stable
Key Features
* Double Spider
* Impedance: 4 ohms
Woofer Features
* Double Spider
* Impedance: 4 ohms
* Sensitivity: 93dB
Specifications:
* Force Factor (Bl)
* Moving Mass (Mms)
Re: Guaging Interest - Kenwood KAC-7201 800W amp/ 2 Kenwood 12" Typhoon Subs
Now on Ebay - http://cgi.ebay.com/Kenwood-12-Typho...QQcmdZViewItem
