trunk mount batt circuit breaker
Old 05-09-2010, 09:02 PM
paxtonLT1's Avatar
hey im moving the batt to the trunk and want to run a circuit breaker for peace of mind. I found them in 150 and 200 and 300 amp and whated to know what would be best. I Dont what it to trip when cranking but it still needs to trip if theres a small short. heres the ebay item # 400007585623. Also sorry if this is the wrong place to put this. thanks for your help guys.
paxtonLT1 is offline
Old 05-10-2010, 10:50 AM
Z28SORR's Avatar
Go to the bottom of your other post and click on the EDIT button. Then delete it.
If mounted properly, a short at your trunk mounted Bat. should be no more of a concern then your engine compartment mounted Bat. Also circiut breakers for such large amp system are not normally used because most shorts would not pop the breaker. You would just feed the short and it would continue to burn. Even a fusable link would not be much use. The best defence is to properly mount and install the Bat. & cables.
You know many cars have there Bats. mounted in the car or trunk from the factory. All the old Corvettes had their Bats. behind the seats and Miata's have their Bats. in the trunk. No cb's or fuses.
P.S. This is probably not advanced Tech. either.
Z28SORR is offline
Old 05-10-2010, 11:55 AM
This topic was covered recently.... a "search" turned up this thread:
https://www.camaroz28.com/forums/sho...ircuit+breaker
Injuneer is offline
Old 05-10-2010, 06:14 PM
paxtonLT1's Avatar
well mostly just ppl saying use the ford setup but I think im going to give the 200amp cb a try and make sure I "properly mount and install the Bat. & cables." and I think I should be safe
z28cam1993
09-09-2015 04:08 AM
4586
08-24-2015 11:04 PM
Bxlt1
07-18-2015 02:48 PM
Noer
Parts Wanted
07-04-2015 05:13 PM
Quick Reply: trunk mount batt circuit breaker
