Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
There for my 11/32'' valve (Staineless steel) and .530'' valve guide cast iron heads.
It will have a no hotter than a 180 thermo, Mobil 1 oil, wet sump oiling, no valve stem cups, single spring with a spirl damper, .511'' lift, top engine speed of 6500 rpms, forced induction (TT's), direct port fuel injection (some fuel contact with intake valve stem), most likely be run a little rich, it should only pull about 20'' of vaccume and have a low $ engine crank case evacuation pump.
Teflon is said to be for race engines and viton is the better stock replacement.
What do you think I should run???
Viton or Teflon?
I have been to the Viton web site and seen all its specs when used as O rings and pump seals.
Teflon is teflon I use those seals all the time on hyd system seals to gas turbine compressor stage seals, many uses.
This ad is not displayed to registered members. Register your free account today and become a member on CamaroZ28.com!
__________________ http://www.cardomain.com/id/oil_pan_4
1985 Iroc Z, LG4, TH700, t-tops, 145mph speedo, electric cooling pump, electric fans.
Have lots of parts to put on, heads, headers, intake manifold, Aluminum driveshaft.
Viton or Teflon?
Seals like Pioneer OS-966 spring loaded viton rubber in steel shell is the best seal to use (.500" guide OD and screw-on threaded OD with Atlas seal pliers)
or Comp Cams viton seals or other brand seals are very much superior to solid White Teflon seals
Seal Ranking (as far as Lasting/Endurance and actual sealing/oil control)
1st = Viton rubber (spring loaded, in steel shell)
2nd= floating Teflon ring in rubber shell
3rd= white solid Teflon seals
4th= Umbrella and Viton rubber umbrella
every ProStock Car or the Old ProStock Truck heads i've seen
have nothing but screwed-on Viton Rubber / spring-loaded valve stem seals ...never seen any of these type heads use solid white teflon seals
I don't realy want to do screw on just push on.
I have been looking at spring loaded and sleved teflon and viton (same set up just different materal).
Down here at the grass roots level of "what works and what doesn't" I have come to rely on the spring-loaded viton rubber seals with the metal shell around the bottom part.
I used to use the Crane teflon (white plastic) seals for a long time. They are good seals, but they are basically junk if you ever have to remove them. And I believe the claim that they don't last quite as long. My motors are usually "weekend fun" motors and they seem to last plenty of weekends, but I doubt they have factory-type longevity. They also exhibit "weird" sealing problems sometimes. You'll sometimes get one that won't seal even though it looks just fine.
The spring-loaded metal-encased Viton seals are the latest and greatest. The factory uses them (Vortec heads) and they are super-easy to deal with for installation/removal. They always seal up. And they don't self-destruct the instant you have to pull them back off the valve stem past the valve lock groove.
I have never used screw-on seals. That kinda stuff is way outta my league.
__________________
1990 454SS pickup. New engine under construction.
Grandma's old 78 Malibu (33K miles!) with a mild roots-blown 383.
Its some work but for extream sbc heads I know a few guysthat have changed the guides to the smaller metric dia size stems and running the honda type seals. Two benifits are lighter valves, smaller seals that allow larger size springs to be run..
...never mind I'm rambling again
using Viton Rubber as a Valve Stem Seal is a great choice,
after all, Viton Rubber is used in as needle/seat material in Carbs,
that just sitting in hot corrosive gasoline all day long, and still seals great in that environment for years.
__________________
Meaux Racing Heads
MaxRace Software
ET_Analyst for DragRacers
http://www.maxracesoftware.com/
i agree, my .02 i am using those same valve seals!
__________________
1996 Camaro SS HRE 399 Liberty's Gears T56 Lozon Fab. Best 60': 1.27
8.81@155.05mph N2O 1.30 60'/10.05@135.14mph,NA 1.39 60'
Quickest and Fastest m6 F Body, 1st LT1 m6 in the 9's & 8's. 1st m6 F body to crack 150 mph.
I used to use the Crane teflon (white plastic) seals for a long time....They also exhibit 'weird' sealing problems sometimes. You'll sometimes get one that won't seal even though it looks just fine.
This is not to state I endorse teflon for street use, or that I don't use the viton myself, but teflon, AFAIC, should be installed dry. By that, I am stating no oil on seal or v. stem, when installing. This may account for some varying degrees of success/failure, in regards to oil control with the teflon seal.
__________________
Da mind...can be a terrible ting!
"This is a republic, NOT a democracy- let's keep it that way!" Hmmm.... don't know the diff?
There is power in knowledge, which is essential in removing the 'matrix'..
I've always been a fan of viton seals. They have a slightly higher cost but are much more durable and have less drag on the valve. Plus they have a smaller OD which means that they can take a bigger spring or a spring with a smaller ID which can help if you are worried about spring weight.
