tach wirring
Old 09-13-2008, 03:09 PM
davisck2's Avatar
tach wirring
can any help me with this problem. I have a 2000 camaro and I just put an aftermarket tach in it and dont know where to wire the green tach signal wire into. thanks for anyones help.
davisck2 is offline
Old 09-14-2008, 01:18 AM
Steve in Seattle's Avatar
1) Do a search, this has been addressed ad-nosium for a simple install.
2) If you are hooking up 2 or 3 tach feeds to the PCM you'll need to get a little more elaborate due to noise in the signal (don't worry about the PCM though, it's just an output wire and won't after engine controls). Again, i know this has also been addressed before.
Steve in Seattle is offline
Old 09-14-2008, 08:47 AM
fxgs's Avatar
On the lower pcm, the #10 output wire, which is WHITE in color
fxgs is offline
Old 09-14-2008, 01:27 PM
V6 or V8? That will determine which forum this belongs in.
Injuneer is online now
mr28
04-20-2016 05:44 PM
Zee man
02-12-2015 07:07 AM
ldtantlinger92
01-19-2015 01:26 PM
mr28
11-23-2014 11:11 AM
Quick Reply: tach wirring
