question on titanium valves
I was wondering if there would be any advantage to use Ti valves in a street/strip type engine.. for example with say a peak RPM of 6500 - 6700. I know that Ti has advantages in high RPM applications due to its light weight, but is there any advantage at the 6500 RPM level? Also what is the lifespan of Ti versus typical valves guys are using for example ferra 6000's or comprable.. Would there be any technical reason NOT to use them if the price wasn't a concern?
titanium valves are very expensive, and are really only good for 1 maybe 2 seasons. after that they can get very hard and brittle. if your only spinning your motor to 6500 I would not even think about Titanium valves. my old motor I had in another car had s/s valves and I spun it to 8600 rpms.
You don't need them for 6,500rpm. They are very expensive and hard to machine. The light weight can make a huge difference in the rpm potential of an all out motor, especially where large valves are used. A very nice alternative, if lighter valves are needed, are hollow stem steel valves. As far as longevity, I don't know of any issues but I never thought about using them in a street car. OTOH, the LS7 does use them and has a 100K warranty.
Rich
Rich
I have caught my self thinking a lot about little things that could be changed to gain a few more HP over the normal setups that you see.. a lot of guys have the same or similar heads and cam combos, and rotating assemblies.. so for some reason when I do get the opportunity to build up my motor, I want to have a few more HP than one would normally expect. for example if a given Head/cam combo is consistanly making 420 RWHP, I want to run a similar Head/cam combo and end up with 450 RWHP. I already have a couple things on my wish list, but still just thinking and planning. I am starting to think that aiming for the lightest weight crank/rods/pistons, may be a good area to focus on.
Not unless the valves are not being controlled with existing components. What Ti valves accomplish is to allow valve control at higher rpm and/or with more aggressive ramps at a given spring pressure.
Rich
Rich
oldschool
02-09-2016 09:21 PM
99TransAmWS6
02-03-2015 08:27 AM
GA93FORMULA
07-24-2002 11:38 PM
