Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 F-Body Technical Discussion > 1967-2002 Specific Technical Discussion > Advanced Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 06-18-2007, 08:47 PM   #1
question on titanium valves
I was wondering if there would be any advantage to use Ti valves in a street/strip type engine.. for example with say a peak RPM of 6500 - 6700. I know that Ti has advantages in high RPM applications due to its light weight, but is there any advantage at the 6500 RPM level? Also what is the lifespan of Ti versus typical valves guys are using for example ferra 6000's or comprable.. Would there be any technical reason NOT to use them if the price wasn't a concern?
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1997 Trans Am M6, 2005 GMC Sierra Z71
www.nitrousoutlet.com
white97T/A is offline   Reply With Quote
Old 06-19-2007, 01:18 AM   #2
BMoney's Avatar
titanium valves are very expensive, and are really only good for 1 maybe 2 seasons. after that they can get very hard and brittle. if your only spinning your motor to 6500 I would not even think about Titanium valves. my old motor I had in another car had s/s valves and I spun it to 8600 rpms.
__________________
1996 Firebird 421 SBC, Th400, moser 9" stock suspension, full interior, streetable car. so far best of 9.96 @138 mph ALL MOTOR!
BMoney is offline   Reply With Quote
Old 06-19-2007, 01:39 AM   #3
Quote:
Titanium valves only last one or two seasons?? Are you sure?? Don't titanium valves come factory on all sport bikes and many sports cars? The Z06 comes with titanium valves and I'm sure many other OEM cars do as well. I thought the only negative about titanium valves would be cost. So if cost weren't a factor then everyone would want them for reliable performance?
Built LT1 is offline   Reply With Quote
Old 06-19-2007, 04:32 AM   #4
Moderator
rskrause's Avatar
Send a message via AIM to rskrause
You don't need them for 6,500rpm. They are very expensive and hard to machine. The light weight can make a huge difference in the rpm potential of an all out motor, especially where large valves are used. A very nice alternative, if lighter valves are needed, are hollow stem steel valves. As far as longevity, I don't know of any issues but I never thought about using them in a street car. OTOH, the LS7 does use them and has a 100K warranty.
Rich
__________________
'95 Z-28 383: Procharger, nitrous, etc. BBC 27T race car. "Every man dies, not every man really lives" William Wallace (Braveheart)
rskrause is offline   Reply With Quote
Old 06-19-2007, 10:35 AM   #5
Send a message via Yahoo to 95ttoplt1
Quote:
Rich
And they aren't dropping valves like the 6.1 hemi with hollow steel valves are. Kind of a funny thought.
__________________
Currently: GM847, 4.30, 3k stall, 7.89@89 In the Stand: 370, All-Pro's, Jesel,Wilson,Crower, AI For sale: Vic-E Converted for EFI, Will bolt to LT1 heads(not raised port) Pm me for details Wanted Perimeter Bolt fabbed valve covers, vaccum pump, Tubular K member, Tubular A-Arms.
95ttoplt1 is offline   Reply With Quote
Old 06-19-2007, 12:39 PM   #6
If the LS7 had steel valves it wouldn't last 100,000 miles. A 86g stock valve in Ti would be more around 120+g which is seriously heavy and not going to last 100,000 miles with any valvespring.
Bret
SStrokerAce is offline   Reply With Quote
Old 06-19-2007, 10:34 PM   #7
Is this fancy or to help your setup? Post all your specs and I'll bet you will be able to get it sorted out in quick fashion with the brain power that will follow.
Dan Parker '96 is offline   Reply With Quote
Old 06-20-2007, 10:50 AM   #8
Quote:
I don't really have any specs per se.. was just asking more from a "bench racing" perspective... if on any given engine if you dropped in lighter valves, with no other changes would you see any gains? After further evaluation I am thinking no. Obviously there is more to consider in the whole package to determine if a particular engine needs lighter valves to work properly (eliminate/ reduce valve float) and gain longevity(by not breaking springs) etc.
I have caught my self thinking a lot about little things that could be changed to gain a few more HP over the normal setups that you see.. a lot of guys have the same or similar heads and cam combos, and rotating assemblies.. so for some reason when I do get the opportunity to build up my motor, I want to have a few more HP than one would normally expect. for example if a given Head/cam combo is consistanly making 420 RWHP, I want to run a similar Head/cam combo and end up with 450 RWHP. I already have a couple things on my wish list, but still just thinking and planning. I am starting to think that aiming for the lightest weight crank/rods/pistons, may be a good area to focus on.
__________________
Old 06-20-2007, 03:20 PM   #9
Moderator
rskrause's Avatar
Not unless the valves are not being controlled with existing components. What Ti valves accomplish is to allow valve control at higher rpm and/or with more aggressive ramps at a given spring pressure.
Rich
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
