piston coatings
Old 05-11-2008, 01:18 AM
Daniel6718's Avatar
piston coatings
anyone have pics of them...guys telling me these pistons are coated but doesnt know what coating...they are boost pistons from diamond, the tops look dull silver...sides i wouldent know...dont know if i can call diamond or not but al lthe coated pistons ive seen are bronze on the top and black i think on the sides? anyone have pics of some and what coating it is?
Daniel6718 is offline
Old 05-11-2008, 07:31 AM
The_Bishop's Avatar
Pictures might help a bit.
The_Bishop is offline
Old 05-12-2008, 10:50 AM
PortMasters's Avatar
Check on our website under coatings, we have a pick of some that sound like what you are dealing with. We coat our piston tops with a CBX thermal dispersant. The color is dull silver after curing in the ovens. On our skirts we use a TLMB coating wich is a moly based dry film that is flat black in color.
PortMasters is offline
Old 05-12-2008, 10:52 AM
mdacton's Avatar
What good does it really do? not many people do it...seems like a waste of money to me
mdacton is offline
Old 05-12-2008, 12:04 PM
Well in a sence you are correct actually,
Say you take a bone stock LS1 or LT1 engine and thermal coat everything inside and out while also coating everything with anti-friction coatings...Gain? Maybe 2 or 3 horsepower but longer engine life and better wear patterns, but in my opinion..not worth the cash.
However,
On a N/A race motor, boosted, or N20 engine the gains are much better. You are able to run higher compression ratio's on N/A set ups than you can on non coated parts, decreased hot spots on the piston tops and combustion chambers under boost and nitrous. The best thing about the dry film anti friction coatings is they actually grab and retain oil so higher rpms when your pan is a little light on volume your parts are still coated with oil and gives you extra insurance, besides that they reduce friction and free up a little power also. The other way they help power, is by taking the heat generated by the fuel burn and turn it into efficiency rather than allowing the heat to soak into the metals.
There is a great debate with coatings and the truth is on a street motor..I wouldn't spend the money. Just being honest here. On a street motor that sprays a 150 shot or higher of N20..I would say do it just to help prevent detonation and save the motor. Race or high compression set ups..I consider it a must for a lasting set up.
Old 05-12-2008, 06:02 PM
93DGTA's Avatar
However,
Glad to hear that i myself have always wondered about that
93DGTA is offline
football4life
10-04-2015 07:48 AM
CARiD
09-30-2015 05:44 AM
Z Power
09-19-2015 11:19 PM
blaze309
09-08-2015 05:27 PM
Quick Reply: piston coatings
