Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 F-Body Technical Discussion > 1967-2002 Specific Technical Discussion > Advanced Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 01-31-2005, 09:38 AM   #1
Offset vs. Centerline solid roller lifters?
When is it recommended to use an offset lifter instead of a centerline lifter?
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1995 Formula 383, BRE Solid Roller Cam, Larry Meaux AFR 227s, LE Victor E, Nitrous Express Plate, Fast XFI, M6
Black95Form is offline   Reply With Quote
Old 01-31-2005, 10:01 AM   #2
Moderator
rskrause's Avatar
Send a message via AIM to rskrause
Re: Offset vs. Centerline solid roller lifters?
If you have to ask, you don't need offset lifters. They are for exotic heads that have had the pushrods relocated to maximize airflow.
Rich
__________________
'95 Z-28 383: Procharger, nitrous, etc. BBC 27T race car. "Every man dies, not every man really lives" William Wallace (Braveheart)
rskrause is offline   Reply With Quote
Old 01-31-2005, 11:45 AM   #3
Some of the larger more exotic race heads have different valve spacing and require offset lifters to correctly orient valve train geometry. For example, my SB2 heads are going to use a .150" offset lifter to make the pushrod angle right. 90% of the stuff you'll see for a sbc will be standard and almost everything you need for an LT1 will be standard.
__________________
95Z 396 SB2.2 LT1, NX, G-force GF5R
9.98 @ 137 1.47 60' All Motor @ 3730 lb raceweight
Sonsored by: SPOHN Performance. Additional Help from: PCMFORLESS.com, G-Force Transmissions, Ken's Kustom Chassis, Second Street Speed and Nitro Dave's
N20Dave is offline   Reply With Quote
Old 01-31-2005, 12:18 PM   #4
What about the AFR 227. I am going to run a jesel shaft mount rocker which is made for the 60/40 valve spacing. Would this require an offset lifter?
__________________
Old 01-31-2005, 02:14 PM   #5
I don't know if the 227's are on a different spacing than my AFR 220's, but the 220's are borderline. I'm using std centered lifters and rockers, but could have went with offset and had slightly better geometry.
Turbo6 is offline   Reply With Quote
Old 02-01-2005, 10:50 AM   #6
AFR only requires offset liftes on their 215RRs (.180" offset). Offset stud girdles are recommended for the 220 & 227 heads though (i.e. not required).
__________________
-Methlab Racing-
'95 Trans Am: twin-turbo LT1, 9", TH400 & FOR SALE
'89 Mustang black primered coupe: SOLD
'88 Mustang LX: 8 cylinders, 4 wheels, 4 barrels, one big plate
'05 GMC Sierra: The only thing I own that isn't modified...yet.
mongse_1 is offline   Reply With Quote
Old 02-06-2005, 01:05 PM   #7
Thumbs up Re: Offset vs. Centerline solid roller lifters?
Quote:
Yes you would want the offsets if you're actually gonna buy that Jesel set and you have to choose the intake offset when you order, Call me as I am a JESEL dealer as well as being a sponsor here. Get the ones offset .350 or .450 (Damn cant remember right now!) and the .150 offset lifters for the intakes so you can run some real pushrods. 90 percent do this but as has been said you don't "have" too in order to run but the 227s are different valve spacing and so are the 215RR heads and they use the exact same stands too.
__________________
Erik Koenig
SamRacing.com
racer7088 is offline   Reply With Quote
Old 02-06-2005, 09:51 PM   #8
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
michael,
mine aren't offset. i ordered the SS shaft mounts last year right from jesel.
just my .02
__________________
1996 Camaro SS HRE 399 Liberty's Gears T56 Lozon Fab. Best 60': 1.27
8.81@155.05mph N2O 1.30 60'/10.05@135.14mph,NA 1.39 60'
Quickest and Fastest m6 F Body, 1st LT1 m6 in the 9's & 8's. 1st m6 F body to crack 150 mph.
taner is offline   Reply With Quote
Old 02-09-2005, 10:09 PM   #9
Send a message via AIM to LT4orbust
i seen a set of offset solid roller lifters for sale on e bay, can they be used with no other supporting parts, will the slight angle hurt anything at high rpm or any rpm
LT4orbust is offline   Reply With Quote
Old 02-09-2005, 10:24 PM   #10
I would strongly recommend not buying offset lifters and just trying to make them work. Proper valvetrain geometry is crucial to making everything stay together. Offset lifters should only be used if you have to.
__________________
Old 02-10-2005, 03:12 AM   #11
It is better to get the correct shaft rockers than offset lifters. Sometimes they are required to take the angle out of the push rod.
A little angle won't hurt,look at a BB Ford or Chevy.
If you are planning to shift at 9,500 then the straighter the better.
No,the AFR 227 don't need offset anything. The rockers will set at an angle to the head like a TFS head on a Ford.
1racerdude is offline   Reply With Quote
Old 02-14-2005, 10:40 PM   #12
1RacerDude,
If offset rockers are not required on a AFR227, why is it it requires an offset stud girdle? Maybe I just dont understand.
Michael
__________________
Old 02-14-2005, 10:46 PM   #13
Go to AFR's sight and see. The valve spacing is different than a 210,ect,the rockers sit at an angle to the head like a TFS on a Ford.
The studs are in a different place than the valves,hence the angle of the rockers.
The studs are not directly behind the valve and a standard girdle would not let you install the valve covers.One end on each head would be sticking out over the gasket boss.
Old 02-15-2005, 12:36 PM   #14
jimlab's Avatar
AFR 215cc RR heads. Note the position of the intake valves in relation to the intake ports.
http://home.gci.net/~jimlab/images/H...d/P1020025.jpg
http://home.gci.net/~jimlab/images/H...d/P1020031.jpg
Offset lifters (0.180" intake) and rockers (0.450" intake, 0.100" exhaust).
http://home.gci.net/~jimlab/images/Misc/P6200017.jpg
http://home.gci.net/~jimlab/images/E...d/P1190101.jpg
According to the Crower catalog, the AFR 220s and 227s use the same rocker offset and the 180s and 210s have a 0.250" intake offset.
jimlab is offline   Reply With Quote
Old 02-15-2005, 01:39 PM   #15
The AFR227s have offset valve locations and to get the most correct geometry is why you use the offset lifters too! You guys are getting confused and you're also believing the AFR catalogue is right! The 227 and 215RR have the same stands in REALITY but not in the catalogues.
__________________
Erik Koenig
SamRacing.com
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
