my dad is going bonkers!
Old 08-11-2008, 07:15 PM
axehead's Avatar
he turns 70 later this year & has bought a big solid roller cam, built a 406 shortblock, & bought an s10 for the motor to go in. he also bought some AFR's, 210's with comp porting. what's the difference between the race ported ones & the comp ported ones. will they need any additional porting?
axehead is offline
Old 08-11-2008, 09:21 PM
automotivebreath's Avatar
Here's a post from speed talk that might help...
Originally Posted by Tony Mamo @ AFR
...ALL the new 23' SBC head we offer are technically part of the new "Eliminator" line....its just that we offer two versions....the street version and the more expensive Comp version which flows a little more at the same port volume and has much finer CNC porting for more accurate results and a more aesthetically pleasing finer finish (the most important part of the Comp version is the finer level porting equals less material removal with every pass of the CNC cutter, and that means less tool deflection and a more accurate reproduction of the prototype port it was digitized from and meant to copy)....
automotivebreath is offline
Old 08-12-2008, 06:47 PM
axehead's Avatar
thx, i might nab them and sock them on my LT1 :-)
axehead is offline
Old 08-15-2008, 01:51 PM
blue 79 Z/28's Avatar
gen 1 sbc heads wont fit on an LT1 unfortunately.
blue 79 Z/28 is offline
Old 08-15-2008, 06:35 PM
axehead's Avatar
i thought that there is a way to convert them to fit on an LT1, am i wrong?
axehead is offline
Old 08-15-2008, 06:39 PM
neil350's Avatar
It;s under 500, but Gen I heads can be converted. Most of the larger machine shops that mess with Lt1s can convert a set for you.
neil350 is offline
Jeff1904
06-05-2016 05:00 PM
Pestilence
3rd Gen / L98 Engine Tech
08-18-2015 10:16 AM
BMX Dad
08-15-2015 01:15 PM
pineapplesink6
06-14-2002 03:41 PM
Quick Reply: my dad is going bonkers!
