idleing and check engine light help!!!
Old 06-06-2010, 02:08 PM
jcamaro3800's Avatar
so ive been having this problem for a while now and ive tried everything i could possible think of. I have a 94 3.4l automatic and its having a rough idle and a check engine light thats going off and on.
the codes came up as the EGR, IAC, and TPS so i replaced them. That lowered the idle from about 1800rpms to 1500 rpms in nuetral/park and to about 1000 rpms when in drive. so my next though was tune up/vaccum leak. so replaced the wires, ignition, and plugs with performance parts and triple checked everything. she ran way smoother but still the idle and check engine light came on and off. when doing a vaccum check i discovered that there was a great amount of suction coming from the area were you put oil in and also that when i choked the Throttle boddy the engine was still running!!! i choked the PCV air in tube and the idle dropped to 800 in park. I must add that the A/C is not blowing cold and oil pressure gage will drop to 0 some times when not on the gas. any ideas of whats wrong would be amazing thanks
jcamaro3800 is offline
Old 06-06-2010, 02:11 PM
oh another thought was the CAT is bad cause there is some rattling coming from down under but an exhaust shop said that on OBD1's the cat wouldnt come up on the codes so my service engine light wouldnt be on?
Ive also checked the PCV valve its working
Old 06-07-2010, 05:15 AM
PLEASE POST ON THE CORRECT FORUM
https://www.camaroz28.com/forums/advanced-tech-38/notice-what-forum-what-not-please-read-47092/
Injuneer is offline
bfmv13trivium
01-14-2015 09:57 AM
dirtybird81
10
01-06-2015 09:31 PM
01-05-2015 07:14 PM
cmdeshon
12-27-2014 10:06 AM
ro2207
12-04-2014 06:18 PM
Quick Reply: idleing and check engine light help!!!
