How high will this motor spin?
Old 04-19-2012, 12:33 AM
LT1 POWR's Avatar
Forged 9.2 compression 383 with a TC78.
Cam-224/224 .577/.582 114 LSA
Rockers-crower 1.65
Springs-Comp 26094-16. Seat load: 178lbs @1.900''_Open load: 459lbs @1.275_Rate: 449lbs/in
Lifters-LS7 with about .00416" preload
Currently only spinning to 6000, but would like to turn it up a little. I'm making 600hp and 600ft/lbs spinning to 6000.
LT1 POWR is offline
Old 04-28-2012, 11:00 AM
TurboSS's Avatar
Re: How high will this motor spin?
PCM goes to 7150
TurboSS is offline
Old 12-17-2012, 11:03 AM
engineermike's Avatar
You can spin it higher than 6000, but the more relevant question is should you. Likely, no. With a 383 and only 224 deg of duration with the small T4 78 mm turbo, it's going to be done by 6000. At least, that was my experience. However, it should trap over 145 mph in the quarter shifting at 6000.
engineermike is offline
Old 12-17-2012, 10:53 PM
LT1 POWR's Avatar
What are you putting down if you don't mind me asking? Looks like we have somewhat similar builds.
LT1 POWR is offline
Old 12-18-2012, 05:52 AM
690 rwhp through a TH350/9". About 930 fwhp. 9.9@146 mph at full stock weight++.
Old 12-18-2012, 10:53 PM
LT1 POWR's Avatar
What boost and compression ratio?
LT1 POWR is offline
Old 12-19-2012, 05:42 AM
Around 8.5/1 and 17 psi.
10-31-2016 11:09 AM
ChrisFrez
03-01-2015 01:33 PM
StansZ28
02-19-2015 07:39 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
z28projects4ever
9
07-16-2002 07:48 PM
Quick Reply: How high will this motor spin?
