Calibrating for new k&n cold air intake
what does calibrating my computer for a k&n cold air intake intail when it comes to a 1994 z28 no other mods? or do you recomend a better first mod than cold air intake?
Cold air intake is the best first mod. It will improve air flow into the engine, particularly at high RPM. Since your 94 has a mass-air flow sensor, it will pick up the extra air flow, and the PCM will add the required fuel. The MAF calibration table may be affected slightly, because of the slightly different geometry of the tube approaching the MAF sensor, but the change is so small that the PCM can make the required corrections using the long term fuel corrections.
What's your problem? No need to play forum policeman, and "report this post" every time you feel there is something wrong. In this case, its a "newbie", and I cut him some slack.
With regard to the comments you are making about the moderation, it is against board guidelines to post feedback regarding the moderation and forum procedures as a reponse in the post. If you have a problem with the moderation, contact the moderator by e-mail or PM, or contact the Admins.
94z28jbw
09-08-2002 03:22 PM
ezcheeze15
08-26-2002 01:28 PM
slothgrant
08-22-2002 03:01 PM
