bushed rods...
bushed rods...
quick question. I bought some h-beam forged rods and one of the bushings hast twisted in the small end bore... can this be simply spun back into place?
I have never dealt with bushed rods before so this is new to me.
The bushing is loose in the bore? Never having been run before?
Are they Eagle or some other off-shore brand?
Either way you need to remove the bushing and have the small end bore checked for sizing before pressing in a new bushing, if it were my motor all the bushings would be pulled out to check if one is bad.
They are not new (they look it!).
The bushing is not loose I just happened to notice that the oil holes are not linded up with the oil holes of the rod. I believe they are ohio crank rods
not sure wat that meant!
He meant the same thing I said. They suck.
What you are describing in the above post is either not GOOD, or not RIGHT! If you've ever handled a bushed rod, you'd know the the pin slides right out of it. Shouldn't be NOWHERE NEAR tight enough for the bushing to come out. IMO.
ok but either way the bushing didn't come out, just that the oiling holes didn't line up with the rods oiling holes. which would mean that oil wouldn't get in to oil the pin between the bushing and piston pin. And I have confirmation that they were NOT Ohio Cranks.
so now the question... how would the bushing get spun in the rod? My common sense tells me that it would be a lack of oil. which would seem like a general problem as this would be an area that would require oil to be "sloshed" up into the bottom of the piston skirt. I have never run bushed pistons and never hear of this being a problem but if someone ran their oil low for some rediculous reason wouldn't this more than likely be the "possible" problem?
sleeperZ96BT
09-09-2015 08:28 AM
04-16-2015 09:57 AM
